MShift on GM 6L80?
MShift on GM 6L80?
Can MShift do this?
Philip
Re: MShift on GM 6L80?
From what I understand the 6L80E has its controller built right in to the transmission. To use megashift, you would have to remove that controller and connect directly to the appropriate solenoids. So it's not as easy as using MShift on many other transmissions.
As well, the 6l80E is physically very large, and often won't fit into vehicles designed for other transmissions like the 4L60E. That doesn't mean it can't be done, but does make the 6L80E somewhat less desirable for retrofit applications.
Thanks LanceLance wrote:Philip,
Is there another 6sp (or 8sp) transmission that would work better with Megashift? (that has been done and working?)
Philip
There are 6 speed kits for the 4L80E, its bit expencive if you want a real 6 speed since you need to change some gears as well.
In your case having a lot of BMW in ZA I would look for a ZF8HPxx
