newbee needs help with megashift
- Do I need the range sensor on the side of the transmission or does the mshift input only from the pressure manifold?
- I am planning on using a map sensor for load calculations. Do I need to calibrate the sensor and if so how do I do it?
I think I am forgetting a question but will post it when I remember. thanks in advance.
Re: newbee needs help with megashift
You need three digital signals that will indicate the current manual gear lever position. Generally this is taken from the pressure switch manifold (PSM), but you can use anything that works for you. (http://www.msgpio.com/manuals/mshift/4L80E/4L80e.html)
If you are going standalone, and are using a MAP sensor for load, then you calibrate the MAP sensor using this procedure: http://www.msgpio.com/manuals/mshift/V22tune.html#gn
For example, if your MAP sensor has 0.0 kPa and 0.00 Volts, and 255.0 kPa at 5.00 Volts, but the maximum pressure you expect is 150 kPa (~ 7psi boost) then you have 0% = 0V and 100% = 5*150/255 = 2.94 V. Then you would enter 0% = 0 V and 100% = 2.94 V in the calculator in the link above, and it will give you that slope and intercept values to enter into TunerStudio. In this case they would be 'Load at 0 Volts' = 0 and 'Multiplier' = 34.01.
