CAN confusion
CAN confusion
I get to this point and then I'm not sure what's going on:
Philip
Re: CAN confusion
There are two potential issues here:
1) Make sure you have the correct INI. It appears that you are showing both 5.101 and 5.102. Make sure the INI matches the code you have (5.102 is best, get the code/INI here: http://www.msgpio.com/manuals/mshift/V5code.html)
2) TunerStudio often mixes up the reported firmware version when connecting for the first time using the CANbus. If you get an obvious firmware mismatch that says your current reported firmware is in fact the engine ECU's firmware, you should "connect anyways". The error will only happen once (or at least once until you change firmware). TS has done this for years to me, but it has never caused a problem on my setup (other than the misleading mismatch message).
Re: CAN confusion
Thanks Lance, but did you see this? viewtopic.php?f=4&t=1012&p=5478&sid=bf5 ... f507#p5478Lance wrote: Make sure the INI matches the code you have (5.102 is best, get the code/INI here: http://www.msgpio.com/manuals/mshift/V5code.html)
Philip
