Im using Volvo B230FT + AW30-43 (same as AW30-40 or Toyota A340/A343)
Im having problems with:
-TCC works about 30km and then i need to reset MegaShift (sometimes it helps just remove power cables, uploading same code resets MShift 100% sure and it works like 30km again.)
TCC works like charm first, but then its going to ON-OFF-ON-OFF motion. And i checked (got log) that if i drive 120kmh and usually 5-15% load (got only tps) (my limit tcc 75kmh / load below 25%)
I have also 0-10seconds Hysteris Time. Still same, only lenght of OFF is longer. Its software bug(?) (because log shows steady readings of sensors +75kmh and below 25% load etc)
And some times it locks TCC full on every time i got 4th gear... Even i got 15kmh BELOW limit or even 100% WOT?! Thats super weird.
I got also smaller problems:
-PWM wont work at all (Spare port 2, this gearbox need it just when i change gears)
-RPM is like 1-90 000rpm, settings wont help a thing (weird because its straight from Ignition ecu and its crystal clear signal...) (its disabled now)
-Tempature gauge is -17.8celcius all the time even i upload my OHM's of tempature gauge. Even i upload what ever... (its disabled now)
I have been running 5.101, 5.102, 5.103.
5.101 was working like same, but my gear lever up didnt do a thing.
Sorry bad english, im Finnish.
Im losing my mind with this... Please help.
Thanks, Sami
