Any developers working on Ford transmissions?
Re: Any developers working on Ford transmissions?
Great! I added several things to the code specifically for Ford transmission users, like the voltage divider based shift lever determination (which also free up two inputs for other uses).
I am not working specifically on the E4OD, but will add things that people feel necessary, if there is sufficient demand. I guess the main thing would be to determine what aspects of the E4OD control are required but not 'doable' using the MShift code as it currently stands.
