Line Pressure reading unstable at zero psi
mcneil
Post by mcneil »
Using the Measurement Specialties M3431 from Digikey (the 0-5V sensor in the build guide), my pressure reading is erratic at zero psi. See below plot from the log
Bench setup, looks like this:
In the first part of the log, the cal points are 20 psi/.489V and 480 psi/ 3.951V. It gives good values when I apply shop air pressure to the sensor, but about 20 psi low. When I put in the actual sensor calibration values, line pressure is erratic at zero applied pressure. When I apply 100psi, it settles down and line pressure = applied pressure.
Is line pressure gauge or absolute? Should I not use 0psi as a cal point?
GPIO_MShift_4145.ini
(221.4 KiB) Downloaded 1052 times
(45.61 KiB) Downloaded 1162 times
2014-11-30_09.02.27.msl
(122.88 KiB) Downloaded 1076 times
Re: Line Pressure reading unstable at zero psi
mcneil,
Thanks for spotting this. It looks like something is messed up in the code. In the meantime I would use the table value rather than the 2-point calculations. I will have a look in the line pressure sensor code and post test code here for you to try shortly.
mcneil,
This code should be better (it is on my bench):
Monitor_5095t1.abs.s19
(78.61 KiB) Downloaded 1145 times
GPIO_MShift_5095.ini
(261.03 KiB) Downloaded 1091 times
Let me know if this doesn't fix it for you.
