4L80E code
4L80E code
Re: 4L80E code
4L80E support should be straightforward.
The PWM periods are settable in MegaTune.
The input speed sensor is not used on the 4L60E (I suspect it was used on the 4L80E to simplify installations on diesel engines), but it does have an output shaft speed sensor of course. The standard code normally calculates the input speed from the current gear and output shaft speed, but it also has a provision for a 'tach' input speed sensor to be used in 'standalone' mode (no CAN connection to MegaSquirt-II). So I suspect that could be adapted fairly easily.
The code also lets the user spec the output shaft pulse/mile, etc. directly in MegaTune.
That leaves the dither function. This is not a part of the standard code just yet, but I could easily add it. Something like: if not currently shifting, implement the user-set dither period in seconds (0-255) and the duration (0-25.5), where 0 means no dither. Let me look into it...
Re: 4L80E code
LT401Vette
Re: 4L80E code
Re: 4L80E code
When is the GPIO board to be released? I would like to do beta testing to help out.
Re: 4L80E code
The GPIO board won't be released for production until existing beta testers (there are several) report back on success, or any of their hardware/software issues are understood and fixed. So far, most of the beta testers have not reported anything back at all (the beta units were sent out in September), so we are waiting to hear from them (Marc and Daniel being notable exceptions - they have provided considerable useful feedback on a number of fronts - from the BOM and instructions, to the harware, code bugs, and missing features).
If legitimate users with transmissions installed and ready for testing want additional beta units, I *might* have one remaining. PM me with the deatails of your application and your snail-mail address and I will consider requests for it.
BowlingSuperior
- Site Admin
Re: 4L80E code
Yes, if you are a beta tester please try to find time to test out the unit. Lance has spent a huge amount of time with the code and arranging the beta tester. Any type of testing is helpful, its important because this is the last step before we can release as production.Lance wrote: The GPIO board won't be released for production until existing beta testers (there are several) report back on success, or any of their hardware/software issues are understood and fixed. So far, most of the beta testers have not reported anything back at all (the beta units were sent out in September), so we are waiting to hear from them (Marc and Daniel being notable exceptions - they have provided considerable useful feedback on a number of fronts - from the BOM and instructions, to the harware, code bugs, and missing features).
Thanks - Bruce
beta testing
Re: 4L80E code
Re: 4L80E code
Or did I just not see them?
