GPIO main boards and heat sinks are now available
Matt Cramer
We've also released a GPIO Heat Sink cut from 1/8" aluminum plate. And you can use an Innovate serial cable with the jack. Other items - the jack, cases, application packages, and the like - will be along soon. I'll have some real pictures up soon as well.
Re: GPIO main boards and heat sinks are now available
So Matt.
I ordered the GPIO, heatsink and the voltage reg.
But you say "You'll need to add the connector jack"
Which jack is this?
Matt Cramer
For the serial connection. It uses a KC-300416 stereo jack. We plan on ordering these but you should be able to find an equivalent at Radio Shack or Fry's, or order one from Digi-Key.427v8 wrote:Sweet!
So Matt.
Which jack is this?
That's what I suspected.
Matt Cramer
Correct - forgot to check who carried it.Lance wrote:Just a note, I don't believe the KC-300416 serial jack is available from Digi-Key. Mouser has it, though. Mouser lists it as 161-2502, last time I looked.
leeleatherwood
rufusbooth
Hoping I am not too much of a pain but I was wondering if you had any ETA on the full kits for the megashift 4l60e application yet.
Cheers,
Rufus
