I am investigating suitable hardware for use with a sequential motor cycle gearbox, and wondered if the Megashift would do the job. Basically, there would be three actuators, one for indexing the gear selector barrel, one to operate the clutch, and one for blipping the throttle on downshifts. I'm not bothered if the existing code can't handle this type of application, as I would expect to design my own control strategies. What I am really looking for is a suitable hardware platform, and suitable tools for carrying out parameter tuning and reprogramming. I could possibly design my own hardware, but my time is limited. For the initial system, I would plan to use the existing engine ECU. However, the final solution may well incorporate this as well.
Thanks Lance. I haven't got very far with this project yet, but was wondering if the template code project that you mentioned would run ok on an MS2 ECU. The reason I ask is that I bought one of these a few years ago, but never got round to using it! The MS2 that I have has the V3 pcb and MS2 daughter board. Once the gearbox control part of the project is complete, I would then like to add the capability to control the engine as well from the same hardware. However, the only source code that I can find for engine control is the MS2Extra stuff, but this doesn't appear to use the Code Warrior tool chain. I think this uses a GCC compiler under Linux. The engine is currently a single cylinder KTM with fuel injection and stepper motor idle control.
I ...was wondering if the template code project ... would run ok on an MS2 ECU
GordonP,
Yes, the MShift code will run on an MS-II because they have identical processors (but the I/O circuits will not be optimal, obviously). I have done this many times on the bench. The tach input on MS-II becomes the VSS input, which is handy.
