Megashift and the Ford 5R110
1 is PCS has a universal stand-alone but it doesn't fine tune the trans enough.
2 is this is considered the strongest trans for a diesel pickup in stock form.
3 is I want this in my truck.
From what I read, this is a 6 spd trans that only uses 5 in a given day. It has a hot and cold operation, which according the the ATSG manual, that just changes 4th/5th gears. 4th is a 1.10:1 and 5th is 1:1.
I do have a bit of a problem though. The amount of solenoids...
There are 13 total, 8 of which are essential.
The solenoid data and what solenoids are needed for which gear and TCC solenoid operation:
http://www.superflow.com/Transmission_T ... 5r110w.pdf
The ATSG manual:
http://atsg.com/dyndata/articles/pdf/Fo ... qshift.pdf
Can I do this? If I can, I will make a lot of people happy.
Thanks!
Re: Megashift and the Ford 5R110
The 4.103 beta code ( http://www.msgpio.com/manuals/mshift/V41code.html ) can control up to 8 shift solenoids in up to 8 forward gears with some hardware mods (but obviously other functions cannot be used on those outputs). The release code has up to 7 shift solenoid outputs, but the new code allows the speedo output to be used as a shift solenoid output as well.
The four LED outputs could potentially also be used for shift outputs, if required (again, with some hardware mods).
Also, the code writing is not hard for me to understand but the hardware modding is harder for me. So If I can get the hardware setup, the software shouldn't be hard. So if I ask stupid board questions, I apologize.
Do I need the Intermediate and Turbine shaft speed sensors? Since this is a standalone, I know I don't have to add it but is it a good add-on?
This part here:
makes me think it can be a hardware issue. Is this something I need to mod on the board or software?Four of the solenoids,TCC, OD Clutch, Intermediate Clutch and the Low/Reverse Clutch, are directly proportional which means the pressure output is directly proportional to the applied DC amps. The current is varied between 0 and 1 amp from the PCM, and 1 amp equals maximum pressure in the oil circuit. Three of the solenoids, Line Pressure, Coast Clutch and Direct Clutch, are inversely proportional which means the pressure output is inversely proportional to the applied DC amps. The current is varied between 0 and 1 amp from the PCM, and 0 amp equals maximum pressure in the oil circuit.
I haven't bought anything yet as I want to make sure I get this right the before I buy. However, I have limited access to my brothers truck with this trans so if I need to find anything out, it shouldn't be too hard.
The shift solenoid outputs and their PWM capabilities are listed in item 3 here:
http://www.msgpio.com/manuals/mshift/spareport.html
All 8 outputs have some form of PWM.
I don't know how the OEM controller uses the various shaft sensors - but it may be for fault diagnosis more than actual operational requirements.
The info required is most likely to be found in a factory service manual. But you could find out much of it on a vehicle with an oscilloscope and extensive testing, I suppose.
I'm just grazing for documents now.
John
Ok,johnjohn00 wrote:I might tear into this project in the new year.
John
I feel that the biggest obstacle I can find the ASTG book is as follows,
(page 13)The transmission range
sensor is non-adjustable and is not serviced
independently. The TR-P sensor contains electronic
circuitry that provides the PCM a fixed frequency, at a
duty cycle, for each of the seven positions of the
manual shift lever.
Is there a pwm input that i can use for the lever position?
