Transmission temp gauge reads 250 with engine not started.
ka24deroadster
Re: Transmission temp gauge reads 250 with engine not starte
The code *should* read to 175 C. At 5500 Ohms, you should be at about 11 C (51ºF). Does the gauge ever read anything other than 250º? (Do you happen to have a trans stim? Does the temperature work on the stim?) Is the proper jumper on the temp circuit (PAD02 - GPI3)?
If this was mine, I would check the assembly and component values very carefully against the instructions in step 'F. GPI3 (temperature)' here: http://www.msgpio.com/manuals/mshift/assembly.html
Are you using Celsius or Fahrenheit units? If you have changed these, then you need to make sure to change it in the software AND the project properties.
I have not tried burning thermistor tables using CAN, and can't say for sure that it works. It's not impossible that doing it that way may have corrupted the thermistor table in the MShift code. If this was mine, I would use a serial connection direct to the MShift/GPIO, and use TunerStudio to burn the table directly. The other thing you might try is reloading the code to see if that makes a difference - you might want to get a fresh copy of the S19 file from the site first: http://www.msgpio.com/manuals/mshift/V2code.html
All MShift codes have the GM sensor as a default, but it's possible GM has used different specs over the years, I suppose.
The default table looks like this:
// ADC Volts Temp Ohms
1800, // 0 0.00 82.2 0.0
1800, // 1 0.00 82.2 2.4
1800, // 2 0.01 82.2 4.9
1800, // 3 0.01 82.2 7.3
1800, // 4 0.02 82.2 9.8
1800, // 5 0.02 82.2 12.2
1800, // 6 0.03 82.2 14.7
1800, // 7 0.03 82.2 17.2
1800, // 8 0.04 82.2 19.6
1800, // 9 0.04 82.2 22.1
3479, // 10 0.05 175.5 24.6
3399, // 11 0.05 171.1 27.1
3328, // 12 0.06 167.1 29.6
3264, // 13 0.06 163.6 32.0
3205, // 14 0.07 160.3 34.5
3151, // 15 0.07 157.3 37.1
3101, // 16 0.08 154.5 39.6
3054, // 17 0.08 151.9 42.1
3011, // 18 0.09 149.5 44.6
2970, // 19 0.09 147.2 47.1
2932, // 20 0.10 145.1 49.7
2896, // 21 0.10 143.1 52.2
2862, // 22 0.11 141.2 54.7
2829, // 23 0.11 139.4 57.3
2799, // 24 0.12 137.7 59.8
2769, // 25 0.12 136.1 62.4
2741, // 26 0.13 134.5 64.9
2714, // 27 0.13 133.0 67.5
2689, // 28 0.14 131.6 70.1
2664, // 29 0.14 130.2 72.6
2640, // 30 0.15 128.9 75.2
2618, // 31 0.15 127.7 77.8
2596, // 32 0.16 126.4 80.4
2574, // 33 0.16 125.2 83.0
2554, // 34 0.17 124.1 85.6
2534, // 35 0.17 123.0 88.2
2515, // 36 0.18 121.9 90.8
2497, // 37 0.18 120.9 93.4
2479, // 38 0.19 119.9 96.1
2461, // 39 0.19 118.9 98.7
2444, // 40 0.20 118.0 101.3
2428, // 41 0.20 117.1 104.0
2412, // 42 0.21 116.2 106.6
2396, // 43 0.21 115.3 109.3
2381, // 44 0.22 114.5 111.9
2366, // 45 0.22 113.7 114.6
2351, // 46 0.22 112.8 117.2
2337, // 47 0.23 112.1 119.9
2324, // 48 0.23 111.3 122.6
2310, // 49 0.24 110.6 125.3
2297, // 50 0.24 109.8 128.0
2284, // 51 0.25 109.1 130.6
2272, // 52 0.25 108.4 133.3
2259, // 53 0.26 107.7 136.1
2247, // 54 0.26 107.1 138.8
2235, // 55 0.27 106.4 141.5
2224, // 56 0.27 105.8 144.2
2212, // 57 0.28 105.1 146.9
2201, // 58 0.28 104.5 149.7
2190, // 59 0.29 103.9 152.4
2180, // 60 0.29 103.3 155.1
2169, // 61 0.30 102.7 157.9
2159, // 62 0.30 102.2 160.6
2149, // 63 0.31 101.6 163.4
2139, // 64 0.31 101.1 166.2
2129, // 65 0.32 100.5 168.9
2119, // 66 0.32 99.9 171.7
2110, // 67 0.33 99.4 174.5
2101, // 68 0.33 98.9 177.3
2091, // 69 0.34 98.4 180.1
2082, // 70 0.34 97.9 182.9
2073, // 71 0.35 97.4 185.7
2065, // 72 0.35 96.9 188.5
2056, // 73 0.36 96.4 191.3
2048, // 74 0.36 96.0 194.2
2039, // 75 0.37 95.5 197.0
2031, // 76 0.37 95.1 199.8
2023, // 77 0.38 94.6 202.7
2015, // 78 0.38 94.2 205.5
2007, // 79 0.39 93.7 208.4
1999, // 80 0.39 93.3 211.2
1991, // 81 0.40 92.8 214.1
1984, // 82 0.40 92.4 217.0
1976, // 83 0.41 92.0 219.9
1969, // 84 0.41 91.6 222.7
1962, // 85 0.42 91.2 225.6
1955, // 86 0.42 90.8 228.5
1947, // 87 0.43 90.4 231.4
1940, // 88 0.43 90.0 234.4
1933, // 89 0.43 89.6 237.3
1927, // 90 0.44 89.3 240.2
1920, // 91 0.44 88.9 243.1
1913, // 92 0.45 88.5 246.1
1906, // 93 0.45 88.1 249.0
1900, // 94 0.46 87.8 251.9
1893, // 95 0.46 87.4 254.9
1887, // 96 0.47 87.1 257.9
1881, // 97 0.47 86.7 260.8
1875, // 98 0.48 86.4 263.8
1868, // 99 0.48 86.0 266.8
1862, // 100 0.49 85.7 269.8
1856, // 101 0.49 85.3 272.8
1850, // 102 0.50 85.0 275.8
1844, // 103 0.50 84.7 278.8
1838, // 104 0.51 84.3 281.8
1833, // 105 0.51 84.1 284.8
1827, // 106 0.52 83.7 287.8
1821, // 107 0.52 83.4 290.9
1815, // 108 0.53 83.1 293.9
1810, // 109 0.53 82.8 296.9
1804, // 110 0.54 82.4 300.0
1799, // 111 0.54 82.2 303.1
1793, // 112 0.55 81.8 306.1
1788, // 113 0.55 81.6 309.2
1783, // 114 0.56 81.3 312.3
1777, // 115 0.56 80.9 315.4
1772, // 116 0.57 80.7 318.5
1767, // 117 0.57 80.4 321.6
1762, // 118 0.58 80.1 324.7
1757, // 119 0.58 79.8 327.8
1752, // 120 0.59 79.6 330.9
1747, // 121 0.59 79.3 334.0
1742, // 122 0.60 79.0 337.2
1737, // 123 0.60 78.7 340.3
1732, // 124 0.61 78.4 343.4
1727, // 125 0.61 78.2 346.6
1722, // 126 0.62 77.9 349.8
1717, // 127 0.62 77.6 352.9
1713, // 128 0.63 77.4 356.1
1708, // 129 0.63 77.1 359.3
1703, // 130 0.64 76.8 362.5
1699, // 131 0.64 76.6 365.7
1694, // 132 0.65 76.3 368.9
1690, // 133 0.65 76.1 372.1
1685, // 134 0.65 75.8 375.3
1681, // 135 0.66 75.6 378.5
1676, // 136 0.66 75.3 381.8
1672, // 137 0.67 75.1 385.0
1667, // 138 0.67 74.8 388.3
1663, // 139 0.68 74.6 391.5
1659, // 140 0.68 74.4 394.8
1655, // 141 0.69 74.2 398.1
1650, // 142 0.69 73.9 401.3
1646, // 143 0.70 73.7 404.6
1642, // 144 0.70 73.4 407.9
1638, // 145 0.71 73.2 411.2
1634, // 146 0.71 73.0 414.5
1629, // 147 0.72 72.7 417.8
1625, // 148 0.72 72.5 421.2
1621, // 149 0.73 72.3 424.5
1617, // 150 0.73 72.1 427.8
1613, // 151 0.74 71.8 431.2
1609, // 152 0.74 71.6 434.5
1605, // 153 0.75 71.4 437.9
1602, // 154 0.75 71.2 441.3
1598, // 155 0.76 71.0 444.6
1594, // 156 0.76 70.8 448.0
1590, // 157 0.77 70.6 451.4
1586, // 158 0.77 70.3 454.8
1582, // 159 0.78 70.1 458.2
1579, // 160 0.78 69.9 461.6
1575, // 161 0.79 69.7 465.1
1571, // 162 0.79 69.5 468.5
1567, // 163 0.80 69.3 471.9
1564, // 164 0.80 69.1 475.4
1560, // 165 0.81 68.9 478.8
1556, // 166 0.81 68.7 482.3
1553, // 167 0.82 68.5 485.8
1549, // 168 0.82 68.3 489.3
1546, // 169 0.83 68.1 492.8
1542, // 170 0.83 67.9 496.2
1539, // 171 0.84 67.7 499.8
1535, // 172 0.84 67.5 503.3
1532, // 173 0.85 67.3 506.8
1528, // 174 0.85 67.1 510.3
1525, // 175 0.86 66.9 513.9
1521, // 176 0.86 66.7 517.4
1518, // 177 0.87 66.6 521.0
1514, // 178 0.87 66.3 524.5
1511, // 179 0.87 66.2 528.1
1508, // 180 0.88 66.0 531.7
1504, // 181 0.88 65.8 535.3
1501, // 182 0.89 65.6 538.9
1498, // 183 0.89 65.4 542.5
1494, // 184 0.90 65.2 546.1
1491, // 185 0.90 65.1 549.7
1488, // 186 0.91 64.9 553.3
1485, // 187 0.91 64.7 557.0
1481, // 188 0.92 64.5 560.6
1478, // 189 0.92 64.3 564.3
1475, // 190 0.93 64.2 567.9
1472, // 191 0.93 64.0 571.6
1469, // 192 0.94 63.8 575.3
1466, // 193 0.94 63.7 579.0
1462, // 194 0.95 63.4 582.7
1459, // 195 0.95 63.3 586.4
1456, // 196 0.96 63.1 590.1
1453, // 197 0.96 62.9 593.9
1450, // 198 0.97 62.8 597.6
1447, // 199 0.97 62.6 601.3
1444, // 200 0.98 62.4 605.1
1441, // 201 0.98 62.3 608.9
1438, // 202 0.99 62.1 612.6
1435, // 203 0.99 61.9 616.4
1432, // 204 1.00 61.8 620.2
1429, // 205 1.00 61.6 624.0
1426, // 206 1.01 61.4 627.8
1423, // 207 1.01 61.3 631.7
1420, // 208 1.02 61.1 635.5
1417, // 209 1.02 60.9 639.3
1414, // 210 1.03 60.8 643.2
1411, // 211 1.03 60.6 647.0
1409, // 212 1.04 60.5 650.9
1406, // 213 1.04 60.3 654.8
1403, // 214 1.05 60.2 658.7
1400, // 215 1.05 60.0 662.6
1397, // 216 1.06 59.8 666.5
1394, // 217 1.06 59.7 670.4
1391, // 218 1.07 59.5 674.3
1389, // 219 1.07 59.4 678.2
1386, // 220 1.08 59.2 682.2
1383, // 221 1.08 59.1 686.1
1380, // 222 1.09 58.9 690.1
1378, // 223 1.09 58.8 694.1
1375, // 224 1.09 58.6 698.1
1372, // 225 1.10 58.4 702.1
1369, // 226 1.10 58.3 706.1
1367, // 227 1.11 58.2 710.1
1364, // 228 1.11 58.0 714.1
1361, // 229 1.12 57.8 718.1
1359, // 230 1.12 57.7 722.2
1356, // 231 1.13 57.6 726.3
1353, // 232 1.13 57.4 730.3
1351, // 233 1.14 57.3 734.4
1348, // 234 1.14 57.1 738.5
1345, // 235 1.15 56.9 742.6
1343, // 236 1.15 56.8 746.7
1340, // 237 1.16 56.7 750.8
1338, // 238 1.16 56.6 754.9
1335, // 239 1.17 56.4 759.1
1332, // 240 1.17 56.2 763.2
1330, // 241 1.18 56.1 767.4
1327, // 242 1.18 55.9 771.5
1325, // 243 1.19 55.8 775.7
1322, // 244 1.19 55.7 779.9
1320, // 245 1.20 55.6 784.1
1317, // 246 1.20 55.4 788.3
1315, // 247 1.21 55.3 792.6
1312, // 248 1.21 55.1 796.8
1310, // 249 1.22 55.0 801.0
1307, // 250 1.22 54.8 805.3
1305, // 251 1.23 54.7 809.6
1302, // 252 1.23 54.6 813.9
1300, // 253 1.24 54.4 818.1
1297, // 254 1.24 54.3 822.4
1295, // 255 1.25 54.2 826.8
1292, // 256 1.25 54.0 831.1
1290, // 257 1.26 53.9 835.4
1288, // 258 1.26 53.8 839.8
1285, // 259 1.27 53.6 844.1
1283, // 260 1.27 53.5 848.5
1280, // 261 1.28 53.3 852.9
1278, // 262 1.28 53.2 857.3
1276, // 263 1.29 53.1 861.7
1273, // 264 1.29 52.9 866.1
1271, // 265 1.30 52.8 870.5
1269, // 266 1.30 52.7 875.0
1266, // 267 1.30 52.6 879.4
1264, // 268 1.31 52.4 883.9
1262, // 269 1.31 52.3 888.3
1259, // 270 1.32 52.2 892.8
1257, // 271 1.32 52.1 897.3
1255, // 272 1.33 51.9 901.8
1252, // 273 1.33 51.8 906.4
1250, // 274 1.34 51.7 910.9
1248, // 275 1.34 51.6 915.4
1245, // 276 1.35 51.4 920.0
1243, // 277 1.35 51.3 924.6
1241, // 278 1.36 51.2 929.2
1239, // 279 1.36 51.1 933.8
1236, // 280 1.37 50.9 938.4
1234, // 281 1.37 50.8 943.0
1232, // 282 1.38 50.7 947.6
1230, // 283 1.38 50.6 952.3
1227, // 284 1.39 50.4 956.9
1225, // 285 1.39 50.3 961.6
1223, // 286 1.40 50.2 966.3
1221, // 287 1.40 50.1 971.0
1218, // 288 1.41 49.9 975.7
1216, // 289 1.41 49.8 980.4
1214, // 290 1.42 49.7 985.1
1212, // 291 1.42 49.6 989.9
1210, // 292 1.43 49.4 994.6
1207, // 293 1.43 49.3 999.4
1205, // 294 1.44 49.2 1004.2
1203, // 295 1.44 49.1 1009.0
1201, // 296 1.45 48.9 1013.8
1199, // 297 1.45 48.8 1018.6
1197, // 298 1.46 48.7 1023.5
1195, // 299 1.46 48.6 1028.3
1192, // 300 1.47 48.4 1033.2
1190, // 301 1.47 48.3 1038.1
1188, // 302 1.48 48.2 1043.0
1186, // 303 1.48 48.1 1047.9
1184, // 304 1.49 48.0 1052.8
1182, // 305 1.49 47.9 1057.7
1180, // 306 1.50 47.8 1062.7
1178, // 307 1.50 47.7 1067.6
1175, // 308 1.51 47.5 1072.6
1173, // 309 1.51 47.4 1077.6
1171, // 310 1.52 47.3 1082.6
1169, // 311 1.52 47.2 1087.6
1167, // 312 1.52 47.1 1092.7
1165, // 313 1.53 46.9 1097.7
1163, // 314 1.53 46.8 1102.8
1161, // 315 1.54 46.7 1107.8
1159, // 316 1.54 46.6 1112.9
1157, // 317 1.55 46.5 1118.0
1155, // 318 1.55 46.4 1123.1
1153, // 319 1.56 46.3 1128.3
1151, // 320 1.56 46.2 1133.4
1149, // 321 1.57 46.1 1138.6
1147, // 322 1.57 45.9 1143.8
1145, // 323 1.58 45.8 1149.0
1143, // 324 1.58 45.7 1154.2
1141, // 325 1.59 45.6 1159.4
1139, // 326 1.59 45.5 1164.6
1137, // 327 1.60 45.4 1169.9
1135, // 328 1.60 45.3 1175.1
1133, // 329 1.61 45.2 1180.4
1131, // 330 1.61 45.1 1185.7
1129, // 331 1.62 44.9 1191.0
1127, // 332 1.62 44.8 1196.4
1125, // 333 1.63 44.7 1201.7
1123, // 334 1.63 44.6 1207.1
1121, // 335 1.64 44.5 1212.4
1119, // 336 1.64 44.4 1217.8
1117, // 337 1.65 44.3 1223.2
1115, // 338 1.65 44.2 1228.6
1113, // 339 1.66 44.1 1234.1
1111, // 340 1.66 43.9 1239.5
1109, // 341 1.67 43.8 1245.0
1107, // 342 1.67 43.7 1250.5
1105, // 343 1.68 43.6 1256.0
1103, // 344 1.68 43.5 1261.5
1101, // 345 1.69 43.4 1267.0
1099, // 346 1.69 43.3 1272.6
1097, // 347 1.70 43.2 1278.2
1095, // 348 1.70 43.1 1283.7
1094, // 349 1.71 43.0 1289.3
1092, // 350 1.71 42.9 1294.9
1090, // 351 1.72 42.8 1300.6
1088, // 352 1.72 42.7 1306.2
1086, // 353 1.73 42.6 1311.9
1084, // 354 1.73 42.4 1317.6
1082, // 355 1.74 42.3 1323.3
1080, // 356 1.74 42.2 1329.0
1078, // 357 1.74 42.1 1334.7
1076, // 358 1.75 42.0 1340.5
1075, // 359 1.75 41.9 1346.3
1073, // 360 1.76 41.8 1352.0
1071, // 361 1.76 41.7 1357.8
1069, // 362 1.77 41.6 1363.7
1067, // 363 1.77 41.5 1369.5
1065, // 364 1.78 41.4 1375.4
1063, // 365 1.78 41.3 1381.2
1062, // 366 1.79 41.2 1387.1
1060, // 367 1.79 41.1 1393.0
1058, // 368 1.80 41.0 1399.0
1056, // 369 1.80 40.9 1404.9
1054, // 370 1.81 40.8 1410.9
1052, // 371 1.81 40.7 1416.9
1050, // 372 1.82 40.6 1422.9
1049, // 373 1.82 40.5 1428.9
1047, // 374 1.83 40.4 1434.9
1045, // 375 1.83 40.3 1441.0
1043, // 376 1.84 40.2 1447.0
1041, // 377 1.84 40.1 1453.1
1039, // 378 1.85 39.9 1459.3
1038, // 379 1.85 39.9 1465.4
1036, // 380 1.86 39.8 1471.5
1034, // 381 1.86 39.7 1477.7
1032, // 382 1.87 39.6 1483.9
1030, // 383 1.87 39.4 1490.1
1029, // 384 1.88 39.4 1496.3
1027, // 385 1.88 39.3 1502.6
1025, // 386 1.89 39.2 1508.9
1023, // 387 1.89 39.1 1515.1
1021, // 388 1.90 38.9 1521.4
1020, // 389 1.90 38.9 1527.8
1018, // 390 1.91 38.8 1534.1
1016, // 391 1.91 38.7 1540.5
1014, // 392 1.92 38.6 1546.9
1013, // 393 1.92 38.5 1553.3
1011, // 394 1.93 38.4 1559.7
1009, // 395 1.93 38.3 1566.2
1007, // 396 1.94 38.2 1572.6
1006, // 397 1.94 38.1 1579.1
1004, // 398 1.95 38.0 1585.6
1002, // 399 1.95 37.9 1592.2
1000, // 400 1.96 37.8 1598.7
998, // 401 1.96 37.7 1605.3
997, // 402 1.96 37.6 1611.9
995, // 403 1.97 37.5 1618.5
993, // 404 1.97 37.4 1625.1
991, // 405 1.98 37.3 1631.8
990, // 406 1.98 37.2 1638.5
988, // 407 1.99 37.1 1645.2
986, // 408 1.99 37.0 1651.9
985, // 409 2.00 36.9 1658.6
983, // 410 2.00 36.8 1665.4
981, // 411 2.01 36.7 1672.2
979, // 412 2.01 36.6 1679.0
978, // 413 2.02 36.6 1685.9
976, // 414 2.02 36.4 1692.7
974, // 415 2.03 36.3 1699.6
972, // 416 2.03 36.2 1706.5
971, // 417 2.04 36.2 1713.4
969, // 418 2.04 36.1 1720.4
967, // 419 2.05 35.9 1727.3
966, // 420 2.05 35.9 1734.3
964, // 421 2.06 35.8 1741.3
962, // 422 2.06 35.7 1748.4
960, // 423 2.07 35.6 1755.5
959, // 424 2.07 35.5 1762.5
957, // 425 2.08 35.4 1769.6
955, // 426 2.08 35.3 1776.8
954, // 427 2.09 35.2 1783.9
952, // 428 2.09 35.1 1791.1
950, // 429 2.10 35.0 1798.3
949, // 430 2.10 34.9 1805.6
947, // 431 2.11 34.8 1812.8
945, // 432 2.11 34.7 1820.1
944, // 433 2.12 34.7 1827.4
942, // 434 2.12 34.6 1834.7
940, // 435 2.13 34.4 1842.1
939, // 436 2.13 34.4 1849.5
937, // 437 2.14 34.3 1856.9
935, // 438 2.14 34.2 1864.3
934, // 439 2.15 34.1 1871.8
932, // 440 2.15 34.0 1879.2
930, // 441 2.16 33.9 1886.8
929, // 442 2.16 33.8 1894.3
927, // 443 2.17 33.7 1901.8
925, // 444 2.17 33.6 1909.4
924, // 445 2.17 33.6 1917.0
922, // 446 2.18 33.4 1924.7
920, // 447 2.18 33.3 1932.3
919, // 448 2.19 33.3 1940.0
917, // 449 2.19 33.2 1947.8
915, // 450 2.20 33.1 1955.5
914, // 451 2.20 33.0 1963.3
912, // 452 2.21 32.9 1971.1
910, // 453 2.21 32.8 1978.9
909, // 454 2.22 32.7 1986.7
907, // 455 2.22 32.6 1994.6
905, // 456 2.23 32.5 2002.5
904, // 457 2.23 32.4 2010.5
902, // 458 2.24 32.3 2018.4
900, // 459 2.24 32.2 2026.4
899, // 460 2.25 32.2 2034.5
897, // 461 2.25 32.1 2042.5
896, // 462 2.26 32.0 2050.6
894, // 463 2.26 31.9 2058.7
892, // 464 2.27 31.8 2066.8
891, // 465 2.27 31.7 2075.0
889, // 466 2.28 31.6 2083.2
887, // 467 2.28 31.5 2091.4
886, // 468 2.29 31.4 2099.7
884, // 469 2.29 31.3 2108.0
882, // 470 2.30 31.2 2116.3
881, // 471 2.30 31.2 2124.6
879, // 472 2.31 31.1 2133.0
878, // 473 2.31 31.0 2141.4
876, // 474 2.32 30.9 2149.8
874, // 475 2.32 30.8 2158.3
873, // 476 2.33 30.7 2166.8
871, // 477 2.33 30.6 2175.3
870, // 478 2.34 30.6 2183.9
868, // 479 2.34 30.4 2192.5
866, // 480 2.35 30.3 2201.1
865, // 481 2.35 30.3 2209.8
863, // 482 2.36 30.2 2218.4
861, // 483 2.36 30.1 2227.2
860, // 484 2.37 30.0 2235.9
858, // 485 2.37 29.9 2244.7
857, // 486 2.38 29.8 2253.5
855, // 487 2.38 29.7 2262.4
853, // 488 2.39 29.6 2271.3
852, // 489 2.39 29.6 2280.2
850, // 490 2.39 29.4 2289.1
849, // 491 2.40 29.4 2298.1
847, // 492 2.40 29.3 2307.1
845, // 493 2.41 29.2 2316.2
844, // 494 2.41 29.1 2325.3
842, // 495 2.42 29.0 2334.4
841, // 496 2.42 28.9 2343.5
839, // 497 2.43 28.8 2352.7
838, // 498 2.43 28.8 2361.9
836, // 499 2.44 28.7 2371.2
834, // 500 2.44 28.6 2380.5
833, // 501 2.45 28.5 2389.8
831, // 502 2.45 28.4 2399.2
830, // 503 2.46 28.3 2408.6
828, // 504 2.46 28.2 2418.0
826, // 505 2.47 28.1 2427.5
825, // 506 2.47 28.1 2437.0
823, // 507 2.48 27.9 2446.6
822, // 508 2.48 27.9 2456.2
820, // 509 2.49 27.8 2465.8
818, // 510 2.49 27.7 2475.4
817, // 511 2.50 27.6 2485.1
815, // 512 2.50 27.5 2494.9
814, // 513 2.51 27.4 2504.6
812, // 514 2.51 27.3 2514.5
811, // 515 2.52 27.3 2524.3
809, // 516 2.52 27.2 2534.2
807, // 517 2.53 27.1 2544.1
806, // 518 2.53 27.0 2554.1
804, // 519 2.54 26.9 2564.1
803, // 520 2.54 26.8 2574.2
801, // 521 2.55 26.7 2584.2
800, // 522 2.55 26.7 2594.4
798, // 523 2.56 26.6 2604.5
796, // 524 2.56 26.4 2614.7
795, // 525 2.57 26.4 2625.0
793, // 526 2.57 26.3 2635.3
792, // 527 2.58 26.2 2645.6
790, // 528 2.58 26.1 2656.0
789, // 529 2.59 26.1 2666.4
787, // 530 2.59 25.9 2676.9
785, // 531 2.60 25.8 2687.4
784, // 532 2.60 25.8 2697.9
782, // 533 2.61 25.7 2708.5
781, // 534 2.61 25.6 2719.1
779, // 535 2.61 25.5 2729.8
778, // 536 2.62 25.4 2740.5
776, // 537 2.62 25.3 2751.3
774, // 538 2.63 25.2 2762.1
773, // 539 2.63 25.2 2773.0
771, // 540 2.64 25.1 2783.9
770, // 541 2.64 25.0 2794.8
768, // 542 2.65 24.9 2805.8
767, // 543 2.65 24.8 2816.8
765, // 544 2.66 24.7 2827.9
764, // 545 2.66 24.7 2839.0
762, // 546 2.67 24.6 2850.2
760, // 547 2.67 24.4 2861.4
759, // 548 2.68 24.4 2872.7
757, // 549 2.68 24.3 2884.0
756, // 550 2.69 24.2 2895.3
754, // 551 2.69 24.1 2906.8
753, // 552 2.70 24.1 2918.2
751, // 553 2.70 23.9 2929.7
750, // 554 2.71 23.9 2941.3
748, // 555 2.71 23.8 2952.9
746, // 556 2.72 23.7 2964.5
745, // 557 2.72 23.6 2976.2
743, // 558 2.73 23.5 2988.0
742, // 559 2.73 23.4 2999.8
740, // 560 2.74 23.3 3011.7
739, // 561 2.74 23.3 3023.6
737, // 562 2.75 23.2 3035.5
736, // 563 2.75 23.1 3047.5
734, // 564 2.76 23.0 3059.6
732, // 565 2.76 22.9 3071.7
731, // 566 2.77 22.8 3083.9
729, // 567 2.77 22.7 3096.1
728, // 568 2.78 22.7 3108.4
726, // 569 2.78 22.6 3120.7
725, // 570 2.79 22.5 3133.1
723, // 571 2.79 22.4 3145.6
722, // 572 2.80 22.3 3158.0
720, // 573 2.80 22.2 3170.6
718, // 574 2.81 22.1 3183.2
717, // 575 2.81 22.1 3195.9
715, // 576 2.82 21.9 3208.6
714, // 577 2.82 21.9 3221.4
712, // 578 2.83 21.8 3234.2
711, // 579 2.83 21.7 3247.1
709, // 580 2.83 21.6 3260.0
708, // 581 2.84 21.6 3273.1
706, // 582 2.84 21.4 3286.1
704, // 583 2.85 21.3 3299.2
703, // 584 2.85 21.3 3312.4
701, // 585 2.86 21.2 3325.7
700, // 586 2.86 21.1 3339.0
698, // 587 2.87 21.0 3352.4
697, // 588 2.87 20.9 3365.8
695, // 589 2.88 20.8 3379.3
694, // 590 2.88 20.8 3392.8
692, // 591 2.89 20.7 3406.5
690, // 592 2.89 20.6 3420.1
689, // 593 2.90 20.5 3433.9
687, // 594 2.90 20.4 3447.7
686, // 595 2.91 20.3 3461.6
684, // 596 2.91 20.2 3475.5
683, // 597 2.92 20.2 3489.5
681, // 598 2.92 20.1 3503.6
679, // 599 2.93 19.9 3517.7
678, // 600 2.93 19.9 3531.9
676, // 601 2.94 19.8 3546.2
675, // 602 2.94 19.7 3560.5
673, // 603 2.95 19.6 3574.9
672, // 604 2.95 19.6 3589.4
670, // 605 2.96 19.4 3603.9
669, // 606 2.96 19.4 3618.6
667, // 607 2.97 19.3 3633.2
665, // 608 2.97 19.2 3648.0
664, // 609 2.98 19.1 3662.8
662, // 610 2.98 19.0 3677.7
661, // 611 2.99 18.9 3692.7
659, // 612 2.99 18.8 3707.7
658, // 613 3.00 18.8 3722.9
656, // 614 3.00 18.7 3738.0
655, // 615 3.01 18.6 3753.3
653, // 616 3.01 18.5 3768.6
651, // 617 3.02 18.4 3784.1
650, // 618 3.02 18.3 3799.6
648, // 619 3.03 18.2 3815.1
647, // 620 3.03 18.2 3830.8
645, // 621 3.04 18.1 3846.5
644, // 622 3.04 18.0 3862.3
642, // 623 3.04 17.9 3878.2
640, // 624 3.05 17.8 3894.1
639, // 625 3.05 17.7 3910.2
637, // 626 3.06 17.6 3926.3
636, // 627 3.06 17.6 3942.5
634, // 628 3.07 17.4 3958.8
633, // 629 3.07 17.4 3975.2
631, // 630 3.08 17.3 3991.6
629, // 631 3.08 17.2 4008.1
628, // 632 3.09 17.1 4024.8
626, // 633 3.09 17.0 4041.5
625, // 634 3.10 16.9 4058.3
623, // 635 3.10 16.8 4075.1
622, // 636 3.11 16.8 4092.1
620, // 637 3.11 16.7 4109.1
618, // 638 3.12 16.6 4126.3
617, // 639 3.12 16.5 4143.5
615, // 640 3.13 16.4 4160.8
614, // 641 3.13 16.3 4178.2
612, // 642 3.14 16.2 4195.7
610, // 643 3.14 16.1 4213.3
609, // 644 3.15 16.1 4231.0
607, // 645 3.15 15.9 4248.8
606, // 646 3.16 15.9 4266.7
604, // 647 3.16 15.8 4284.7
602, // 648 3.17 15.7 4302.7
601, // 649 3.17 15.6 4320.9
599, // 650 3.18 15.5 4339.1
598, // 651 3.18 15.4 4357.5
596, // 652 3.19 15.3 4376.0
595, // 653 3.19 15.3 4394.5
593, // 654 3.20 15.2 4413.2
591, // 655 3.20 15.1 4431.9
590, // 656 3.21 15.0 4450.8
588, // 657 3.21 14.9 4469.8
587, // 658 3.22 14.8 4488.8
585, // 659 3.22 14.7 4508.0
583, // 660 3.23 14.6 4527.3
582, // 661 3.23 14.6 4546.7
580, // 662 3.24 14.4 4566.1
579, // 663 3.24 14.4 4585.7
577, // 664 3.25 14.3 4605.5
575, // 665 3.25 14.2 4625.3
574, // 666 3.26 14.1 4645.2
572, // 667 3.26 14.0 4665.3
570, // 668 3.26 13.9 4685.4
569, // 669 3.27 13.8 4705.7
567, // 670 3.27 13.7 4726.1
566, // 671 3.28 13.7 4746.6
564, // 672 3.28 13.6 4767.2
562, // 673 3.29 13.4 4787.9
561, // 674 3.29 13.4 4808.8
559, // 675 3.30 13.3 4829.7
558, // 676 3.30 13.2 4850.8
556, // 677 3.31 13.1 4872.1
554, // 678 3.31 13.0 4893.4
553, // 679 3.32 12.9 4914.9
551, // 680 3.32 12.8 4936.4
549, // 681 3.33 12.7 4958.2
548, // 682 3.33 12.7 4980.0
546, // 683 3.34 12.6 5002.0
545, // 684 3.34 12.5 5024.1
543, // 685 3.35 12.4 5046.3
541, // 686 3.35 12.3 5068.7
540, // 687 3.36 12.2 5091.2
538, // 688 3.36 12.1 5113.8
536, // 689 3.37 12.0 5136.6
535, // 690 3.37 11.9 5159.5
533, // 691 3.38 11.8 5182.5
531, // 692 3.38 11.7 5205.7
530, // 693 3.39 11.7 5229.0
528, // 694 3.39 11.6 5252.5
526, // 695 3.40 11.4 5276.1
525, // 696 3.40 11.4 5299.8
523, // 697 3.41 11.3 5323.7
521, // 698 3.41 11.2 5347.8
520, // 699 3.42 11.1 5371.9
518, // 700 3.42 11.0 5396.3
516, // 701 3.43 10.9 5420.8
515, // 702 3.43 10.8 5445.4
513, // 703 3.44 10.7 5470.2
511, // 704 3.44 10.6 5495.2
510, // 705 3.45 10.6 5520.3
508, // 706 3.45 10.4 5545.6
506, // 707 3.46 10.3 5571.0
505, // 708 3.46 10.3 5596.6
503, // 709 3.47 10.2 5622.3
501, // 710 3.47 10.1 5648.2
500, // 711 3.48 10.0 5674.3
498, // 712 3.48 9.9 5700.6
496, // 713 3.48 9.8 5727.0
495, // 714 3.49 9.7 5753.6
493, // 715 3.49 9.6 5780.4
491, // 716 3.50 9.5 5807.3
490, // 717 3.50 9.4 5834.4
488, // 718 3.51 9.3 5861.7
486, // 719 3.51 9.2 5889.2
484, // 720 3.52 9.1 5916.8
483, // 721 3.52 9.1 5944.7
481, // 722 3.53 8.9 5972.7
479, // 723 3.53 8.8 6000.9
478, // 724 3.54 8.8 6029.3
476, // 725 3.54 8.7 6057.9
474, // 726 3.55 8.6 6086.7
472, // 727 3.55 8.4 6115.6
471, // 728 3.56 8.4 6144.8
469, // 729 3.56 8.3 6174.2
467, // 730 3.57 8.2 6203.8
466, // 731 3.57 8.1 6233.5
464, // 732 3.58 8.0 6263.5
462, // 733 3.58 7.9 6293.7
460, // 734 3.59 7.8 6324.1
459, // 735 3.59 7.7 6354.7
457, // 736 3.60 7.6 6385.5
455, // 737 3.60 7.5 6416.5
453, // 738 3.61 7.4 6447.8
452, // 739 3.61 7.3 6479.3
450, // 740 3.62 7.2 6511.0
448, // 741 3.62 7.1 6542.9
446, // 742 3.63 7.0 6575.0
445, // 743 3.63 6.9 6607.4
443, // 744 3.64 6.8 6640.0
441, // 745 3.64 6.7 6672.8
439, // 746 3.65 6.6 6705.9
438, // 747 3.65 6.6 6739.2
436, // 748 3.66 6.4 6772.8
434, // 749 3.66 6.3 6806.6
432, // 750 3.67 6.2 6840.7
430, // 751 3.67 6.1 6875.0
429, // 752 3.68 6.1 6909.5
427, // 753 3.68 5.9 6944.3
425, // 754 3.69 5.8 6979.4
423, // 755 3.69 5.7 7014.7
421, // 756 3.70 5.6 7050.3
420, // 757 3.70 5.6 7086.2
418, // 758 3.70 5.4 7122.3
416, // 759 3.71 5.3 7158.8
414, // 760 3.71 5.2 7195.4
412, // 761 3.72 5.1 7232.4
410, // 762 3.72 5.0 7269.7
409, // 763 3.73 4.9 7307.2
407, // 764 3.73 4.8 7345.0
405, // 765 3.74 4.7 7383.1
403, // 766 3.74 4.6 7421.6
401, // 767 3.75 4.5 7460.3
399, // 768 3.75 4.4 7499.3
398, // 769 3.76 4.3 7538.6
396, // 770 3.76 4.2 7578.3
394, // 771 3.77 4.1 7618.2
392, // 772 3.77 4.0 7658.5
390, // 773 3.78 3.9 7699.1
388, // 774 3.78 3.8 7740.0
386, // 775 3.79 3.7 7781.2
385, // 776 3.79 3.6 7822.8
383, // 777 3.80 3.5 7864.8
381, // 778 3.80 3.4 7907.0
379, // 779 3.81 3.3 7949.6
377, // 780 3.81 3.2 7992.6
375, // 781 3.82 3.1 8035.9
373, // 782 3.82 2.9 8079.6
371, // 783 3.83 2.8 8123.6
369, // 784 3.83 2.7 8168.0
368, // 785 3.84 2.7 8212.8
366, // 786 3.84 2.6 8258.0
364, // 787 3.85 2.4 8303.5
362, // 788 3.85 2.3 8349.4
360, // 789 3.86 2.2 8395.8
358, // 790 3.86 2.1 8442.5
356, // 791 3.87 2.0 8489.6
354, // 792 3.87 1.9 8537.1
352, // 793 3.88 1.8 8585.1
350, // 794 3.88 1.7 8633.4
348, // 795 3.89 1.6 8682.2
346, // 796 3.89 1.4 8731.5
344, // 797 3.90 1.3 8781.1
342, // 798 3.90 1.2 8831.2
340, // 799 3.91 1.1 8881.7
338, // 800 3.91 1.0 8932.7
336, // 801 3.91 0.9 8984.2
334, // 802 3.92 0.8 9036.1
332, // 803 3.92 0.7 9088.5
330, // 804 3.93 0.6 9141.4
328, // 805 3.93 0.4 9194.7
326, // 806 3.94 0.3 9248.6
324, // 807 3.94 0.2 9302.9
322, // 808 3.95 0.1 9357.8
320, // 809 3.95 0.0 9413.1
318, // 810 3.96 -0.1 9469.0
316, // 811 3.96 -0.2 9525.4
314, // 812 3.97 -0.3 9582.4
312, // 813 3.97 -0.4 9639.9
310, // 814 3.98 -0.6 9697.9
308, // 815 3.98 -0.7 9756.5
306, // 816 3.99 -0.8 9815.7
304, // 817 3.99 -0.9 9875.4
302, // 818 4.00 -1.0 9935.7
299, // 819 4.00 -1.2 9996.6
297, // 820 4.01 -1.3 10058.1
295, // 821 4.01 -1.4 10120.2
293, // 822 4.02 -1.5 10183.0
291, // 823 4.02 -1.6 10246.3
289, // 824 4.03 -1.7 10310.4
287, // 825 4.03 -1.8 10375.0
285, // 826 4.04 -1.9 10440.3
283, // 827 4.04 -2.1 10506.3
280, // 828 4.05 -2.2 10572.9
278, // 829 4.05 -2.3 10640.3
276, // 830 4.06 -2.4 10708.3
274, // 831 4.06 -2.6 10777.0
272, // 832 4.07 -2.7 10846.5
270, // 833 4.07 -2.8 10916.7
267, // 834 4.08 -2.9 10987.6
265, // 835 4.08 -3.1 11059.3
263, // 836 4.09 -3.2 11131.8
261, // 837 4.09 -3.3 11205.0
258, // 838 4.10 -3.4 11279.0
256, // 839 4.10 -3.6 11353.9
254, // 840 4.11 -3.7 11429.5
252, // 841 4.11 -3.8 11506.0
249, // 842 4.12 -3.9 11583.3
247, // 843 4.12 -4.1 11661.5
245, // 844 4.13 -4.2 11740.6
243, // 845 4.13 -4.3 11820.5
240, // 846 4.13 -4.4 11901.4
238, // 847 4.14 -4.6 11983.1
236, // 848 4.14 -4.7 12065.8
233, // 849 4.15 -4.8 12149.5
231, // 850 4.15 -4.9 12234.1
229, // 851 4.16 -5.1 12319.7
226, // 852 4.16 -5.2 12406.3
224, // 853 4.17 -5.3 12493.9
222, // 854 4.17 -5.4 12582.6
219, // 855 4.18 -5.6 12672.3
217, // 856 4.18 -5.7 12763.1
215, // 857 4.19 -5.8 12855.0
212, // 858 4.19 -6.0 12948.0
210, // 859 4.20 -6.1 13042.1
207, // 860 4.20 -6.3 13137.4
205, // 861 4.21 -6.4 13233.9
203, // 862 4.21 -6.5 13331.6
200, // 863 4.22 -6.7 13430.4
198, // 864 4.22 -6.8 13530.6
195, // 865 4.23 -6.9 13632.0
193, // 866 4.23 -7.1 13734.6
190, // 867 4.24 -7.2 13838.7
188, // 868 4.24 -7.3 13944.0
185, // 869 4.25 -7.5 14050.7
183, // 870 4.25 -7.6 14158.8
180, // 871 4.26 -7.8 14268.4
178, // 872 4.26 -7.9 14379.3
175, // 873 4.27 -8.1 14491.8
172, // 874 4.27 -8.2 14605.8
170, // 875 4.28 -8.3 14721.3
167, // 876 4.28 -8.5 14838.4
165, // 877 4.29 -8.6 14957.1
162, // 878 4.29 -8.8 15077.4
159, // 879 4.30 -8.9 15199.4
157, // 880 4.30 -9.1 15323.1
154, // 881 4.31 -9.2 15448.5
151, // 882 4.31 -9.4 15575.7
149, // 883 4.32 -9.5 15704.8
146, // 884 4.32 -9.7 15835.7
143, // 885 4.33 -9.8 15968.5
141, // 886 4.33 -9.9 16103.2
138, // 887 4.34 -10.1 16239.9
135, // 888 4.34 -10.3 16378.7
132, // 889 4.35 -10.4 16519.5
130, // 890 4.35 -10.6 16662.4
127, // 891 4.35 -10.7 16807.5
124, // 892 4.36 -10.9 16954.8
121, // 893 4.36 -11.1 17104.4
118, // 894 4.37 -11.2 17256.3
115, // 895 4.37 -11.4 17410.5
113, // 896 4.38 -11.5 17567.2
110, // 897 4.38 -11.7 17726.4
107, // 898 4.39 -11.8 17888.2
104, // 899 4.39 -12.0 18052.5
101, // 900 4.40 -12.2 18219.5
98, // 901 4.40 -12.3 18389.3
95, // 902 4.41 -12.5 18561.8
92, // 903 4.41 -12.7 18737.3
89, // 904 4.42 -12.8 18915.6
86, // 905 4.42 -13.0 19097.0
83, // 906 4.43 -13.2 19281.5
80, // 907 4.43 -13.3 19469.2
77, // 908 4.44 -13.5 19660.2
73, // 909 4.44 -13.7 19854.5
70, // 910 4.45 -13.9 20052.2
67, // 911 4.45 -14.1 20253.5
64, // 912 4.46 -14.2 20458.4
61, // 913 4.46 -14.4 20667.0
57, // 914 4.47 -14.6 20879.4
54, // 915 4.47 -14.8 21095.8
51, // 916 4.48 -14.9 21316.3
48, // 917 4.48 -15.1 21540.8
44, // 918 4.49 -15.3 21769.7
41, // 919 4.49 -15.5 22003.0
38, // 920 4.50 -15.7 22240.8
34, // 921 4.50 -15.9 22483.2
31, // 922 4.51 -16.1 22730.5
27, // 923 4.51 -16.3 22982.7
24, // 924 4.52 -16.4 23240.0
20, // 925 4.52 -16.7 23502.6
17, // 926 4.53 -16.8 23770.5
13, // 927 4.53 -17.1 24044.1
10, // 928 4.54 -17.2 24323.4
6, // 929 4.54 -17.4 24608.6
2, // 930 4.55 -17.7 24900.0
0, // 931 4.55 -17.8 25197.7
-4, // 932 4.56 -18.0 25502.0
-8, // 933 4.56 -18.2 25813.0
-11, // 934 4.57 -18.4 26131.0
-15, // 935 4.57 -18.6 26456.2
-19, // 936 4.57 -18.8 26789.0
-23, // 937 4.58 -19.1 27129.4
-27, // 938 4.58 -19.3 27477.9
-31, // 939 4.59 -19.5 27834.6
-35, // 940 4.59 -19.7 28200.0
-39, // 941 4.60 -19.9 28574.3
-43, // 942 4.60 -20.2 28957.8
-47, // 943 4.61 -20.4 29350.9
-51, // 944 4.61 -20.6 29753.9
-55, // 945 4.62 -20.8 30167.3
-60, // 946 4.62 -21.1 30591.4
-64, // 947 4.63 -21.3 31026.7
-68, // 948 4.63 -21.6 31473.6
-73, // 949 4.64 -21.8 31932.6
-77, // 950 4.64 -22.1 32404.1
-81, // 951 4.65 -22.3 32888.8
-86, // 952 4.65 -22.6 33387.0
-91, // 953 4.66 -22.8 33899.6
-95, // 954 4.66 -23.1 34427.0
-100, // 955 4.67 -23.3 34969.9
-105, // 956 4.67 -23.6 35529.0
-109, // 957 4.68 -23.8 36105.0
-114, // 958 4.68 -24.1 36698.8
-119, // 959 4.69 -24.4 37311.1
-124, // 960 4.69 -24.7 37942.9
-129, // 961 4.70 -24.9 38595.0
-134, // 962 4.70 -25.2 39268.5
-139, // 963 4.71 -25.5 39964.5
-145, // 964 4.71 -25.8 40684.1
-150, // 965 4.72 -26.1 41428.4
-155, // 966 4.72 -26.4 42198.9
-161, // 967 4.73 -26.7 42997.0
-167, // 968 4.73 -27.1 43824.0
-172, // 969 4.74 -27.3 44681.7
-178, // 970 4.74 -27.7 45571.7
-184, // 971 4.75 -28.0 46496.0
-190, // 972 4.75 -28.3 47456.5
-196, // 973 4.76 -28.7 48455.4
-202, // 974 4.76 -29.0 49495.1
-208, // 975 4.77 -29.3 50578.1
-214, // 976 4.77 -29.7 51707.2
-221, // 977 4.78 -30.1 52885.4
-227, // 978 4.78 -30.4 54116.0
-234, // 979 4.78 -30.8 55402.5
-241, // 980 4.79 -31.2 56748.8
-248, // 981 4.79 -31.6 58159.3
-255, // 982 4.80 -31.9 59638.5
-262, // 983 4.80 -32.3 61191.7
-270, // 984 4.81 -32.8 62824.6
-277, // 985 4.81 -33.2 64543.4
-285, // 986 4.82 -33.6 66355.1
-293, // 987 4.82 -34.1 68267.5
-301, // 988 4.83 -34.5 70289.1
-310, // 989 4.83 -35.0 72429.7
-318, // 990 4.84 -35.4 74700.0
-327, // 991 4.84 -35.9 77112.2
-336, // 992 4.85 -36.4 79680.0
-345, // 993 4.85 -36.9 82419.0
-355, // 994 4.86 -37.5 85346.9
-365, // 995 4.86 -38.1 88483.9
-375, // 996 4.87 -38.6 91853.3
-385, // 997 4.87 -39.2 95481.9
-396, // 998 4.88 -39.8 99400.8
1800, // 999 4.88 82.2 103646.3
1800, // 1000 4.89 82.2 108260.9
1800, // 1001 4.89 82.2 113295.0
1800, // 1002 4.90 82.2 118808.6
1800, // 1003 4.90 82.2 124873.5
1800, // 1004 4.91 82.2 131576.8
1800, // 1005 4.91 82.2 139025.0
1800, // 1006 4.92 82.2 147349.4
1800, // 1007 4.92 82.2 156714.4
1800, // 1008 4.93 82.2 167328.0
1800, // 1009 4.93 82.2 179457.9
1800, // 1010 4.94 82.2 193453.8
1800, // 1011 4.94 82.2 209782.5
1800, // 1012 4.95 82.2 229080.0
1800, // 1013 4.95 82.2 252237.0
1800, // 1014 4.96 82.2 280540.0
1800, // 1015 4.96 82.2 315918.7
1800, // 1016 4.97 82.2 361405.7
1800, // 1017 4.97 82.2 422055.0
1800, // 1018 4.98 82.2 506964.0
1800, // 1019 4.98 82.2 634327.5
1800, // 1020 4.99 82.2 846600.0
1800, // 1021 4.99 82.2 1271145.0
1800, // 1022 5.00 82.2 2544780.0
1800 // 1023 5.00 82.2 2544780.0
ka24deroadster
The default units in the code is ºF, so you don't have to change that in the code (unless you are using someone else's MSQ who used metric, for example). More here: http://www.msgpio.com/manuals/mshift/V2tune.html#gu
The "PAD02" silkscreen label has been shortened to "AD2" on the latest board. I looked at an older board in replying, sorry about that!
AD2-GPI3 is one of the jumpers on the 25x2 header - these pins are directly across from each other (which the instructions ask you to install after cleaning the assembled board and testing a pin's voltage).
These pins (and many others) need to have a jumper on them, or else the CPU pin isn't connected to the temperature circuit at all, and the ADC pin will float (and the temperature returned will likely look much like what you are seeing). If these pins don't have a jumper, put one on. If it does have a jumper on it, you might try removing the jumper and measuring the voltage on the pin on the GPI3 side (and let us know what you find).
FWIW, the temp appears to work fine on the bench with the default code, 5340 Ohms gives me about 50ºF and the indicated temperature changes as the resistance changes.
ka24deroadster
It is stated in the instruction to install the jumpers, it can be easy to over look some of the details25x2 Header {WM8135-ND, S9000-ND}: Before installing the header, you must use insulated wire (~20-22 gauge) to jumper:
AD1 to GPI2 at 25x2 header, and
PT7 to VB1 at 25x2 header.
Do these jumpers first, then cut the 25x2 header with small side cutters to fit remaining holes as necessary. Solder each of the header pins from the bottom side of the board (you can use tape to hold the header in place while it is upside down). For now, do not install jumpers on all the applicable circuits (see the table near the top of this document). You can do that after checking the circuits at the end of the build process.
I am glad this is working for you now. As Dave points out, it is mentioned in the manual, but I can certainly make it more prominent, and will do that shortly.
