First, you will need to provide the MShift a TPS signal. As we know from MSquirt installs on Neons, you can tap into the factory TPS line and have it shared between the PCM and the MShift (or MSquirt as we usually do).
Second, you need to give the MShift a load signal, since it won't be able to get the MAP information via CAN from the MSquirt. There is a circuit on the board that can be used optionally for either EGT1, or non-CAN MAP. This circuit is said to be a voltage sensing circuit for 0-5V, so maybe since the trans shouldn't really care about boost, you can simply tap into the factory MAP wire if you can figure out a voltage to kPa curve.
I'm guessing the FIC has it's own on-board MAP sensor that is boost capable, so maybe it would be more appropriate to take your MAP signal from the output wire from the FIC to the MAP input wire into the PCM?
As far as RPM, I'm guessing this is needed, even though you might be able to extrapolate to your shift points from VSS input. That doesn't sound very safe or precise to me, so I'm thinking the easiest way to go is to tap into a "tach signal" however people did it for MSquirt installs prior to the Neon/420a crankwheel decoder. You probably know exactly how that was done unless I missed my guess on that.
I **think** that's it!
Thad
EDIT: This makes me think I might be wrong about a couple of items in my post:
So for Steve's purposes, potentially using the AEM FIC to run his engine might limit his ability to datalog pressures from within the trans, since that ADC input would be tied up by the MAP or TPS.Lance wrote:There is one dedicated line pressure input, and more free ADC (voltage measuring) inputs that could be used simultaneously for more pressure sensors, depending on things like the shift lever signal (for example, if the shift lever is voltage based rather than digital, there are two more ADC voltage channels available in the current code). There is also an ADC channel freed up if using CAN (w/ MS-II) to get the load (MAP or TPS).
Which brings me to my next potential "wrongness". This makes it look like an either/or thing as opposed to a "both" thing. . . . ?
Another EDIT:
After looking some more at Lance's prior posts in this thread, and looking around elsewhere, I think maybe the RPM input was only in my mind.
