switch for manual mode shifting
Re: switch for manual mode shifting
I would also prefer to use a solution with 2 wires.
How precise do you think the solution with one wire and different resistance could be compared to a solution with 2 wires?
And how good would the horn contact be for this application in a car that is 40 years old? Would you rely on it?
Personally, I would still use the two separate grounding switches even when the code allows for a voltage based shift signal. However others prefer something else for various reasons, and they would have to judge for themselves how well this might work with their setup and hardware.
I haven't forgotten about the voltage based shift buttons. I have code written, and am testing it now. Once it is proven, I will release it as 2.112. There is tentative documentation here: http://www.msgpio.com/manuals/mshift/voltshift.html
I will be testing for a few days, then hope to release the code by the weekend if all goes well (and issues don't pop-up on other fronts). The code will be announced in the code updates thread: viewtopic.php?f=4&t=240 or you can check the code page: http://www.msgpio.com/manuals/mshift/V2code.html
I unfortunately cannot test it as the car is disassembled again, but I hope to test it next spring.
Thank you Lance
This code lets the user specify 4 voltages and a tolerance that correspond to different shift buttons states. This means the shift buttons consume only one input, and makes it possible to turn some horn mechanisms into 'UP/Down' shift buttons.
There is much more on the voltage based shift buttons here: http://www.msgpio.com/manuals/mshift/voltshift.html
