Spare port
Re: Spare port
This will trigger the tacho nicly rather then with the original SP2 build, not working with a floating signal.
The code is working as it should and I can set the pointer spot on where I want it by just changing the frequency.
As soon as I have the gauge ready Ill post a video here.
//Tobmag
Re: Spare port
Yeah, the VB circuits aren't designed for signalling as the default build, so some modifications are necessary. I'm glad you got this sorted out.
I apologize that I have been slow to respond. That is because I was having a mysterious issue with the downshift button function, and I have been digging deep into the code/circuits/stim/etc. to try to figure out what went wrong, only to eventually realize that I somehow managed to burn out an ADC pin on the processor (after many wasted hours...).
Re: Spare port
Welcome to the club, I manage to burn my down shift pin on the processor as well.
Its now always reads as its pressed.
Everythings seems to be working in auto mode anyway.
//Tobmag
Re: Spare port
That is a very odd coincidence. It makes me think I need to look much more closely into the cause of this (which I will do).
