i did do some driving on my factory equipped pickup to see how it reacts more closely, i will try my other car as well when the weather permits, i have a quarterhorse in it and have access ecu and how the factory controlls it so i will do some snooping around.
4r70w setup
Re: 4r70w setup
Re: 4r70w setup
Re: 4r70w setup
Great, I'm glad it's working now. I will look into the 2-point pressure setup next. Thanks for testing this!
Re: 4r70w setup
can i have shift tables based on tps and pressure tables based on map. this would be a huge help on a turbo car. a map based shift tabe is giving me no love.
another thing would be when the gear position is 2 it stays in 2 no downshifting to first.
pwm in neutral to be able to be set lower than 40
a few bugs?
tcc stays locked when decelerating shifting from 4th to 3rd
if i manuall shift(lever) it stays in 1st till mph goes to 0
Re: 4r70w setup
Different load measures for the tables ought to be an easy change, I will look into it. In dealing with these things, it helps if there is a separate thread for each topic, otherwise requests tend to get lost and eventually forgotten. So you might want to start another thread on this.
Having the gear stay in 2nd when the lever is set to 2nd isn't likely to happen. That code always assumes that the lever sets the highest gear, not the only gear. You can get the behavior you want with the current code, though. If you want the trans to stay in 2nd, you need to shift into 2nd using the shift buttons to enter manual mode and shift to 2nd, then the trans will stay in 2nd until you shift or go into auto mode (or exceed the upper or lower rpm limits, if you have enabled them). The general idea is that you should put the lever in P, and then shift with the buttons, that's the point of having an electronic controller with a manual mode and shift buttons.
The PWM minimum is set in the INI. So you can change it just by editing the INI in a text editor (such as notepad.exe). You can find it yourself, our you can wait for me to post the details when I am closer to my main computer.
If you find a bug, please report it by posting a datalog and MSQ that illustrates the problem. Be sure to describe exactly when the problem behaviour starts in the log, what it is actually doing, and what you think it should be doing (ideally based on what the manual says it should be doing). That way we are both looking at the same issue, and can define the problem properly.
Re: 4r70w setup
To change the PWM minimum, find a line in the INI like this:
pc_table = array, U08, 273, [16x9], "%", -1.00000, -100.00, 40, 100, 0 ; The PWM% for PC solenoid by load and mph the 40 value is the minimum. Suppose you wanted to change it to a lower number, say 20. Change the value of 40 to 20, like this:
pc_table = array, U08, 273, [16x9], "%", -1.00000, -100.00, 20, 100, 0 ; The PWM% for PC solenoid by load and mphThen you would be able to set line pressure table values as low as 20. There are other places in the INI where similar limits apply to line pressure settings (minimum line pressure in neutral/reverse, shift pressures, etc.) and you change them in the same way.
However, use great caution doing this! It is possible to set the line pressure too low for the transmission to operate correctly, and you could quickly burn out internal friction elements and/or damage other transmission components.
Re: 4r70w setup
The latest 4.119 beta code ( viewtopic.php?f=4&t=240&p=3323#p3323 ) allows the user to set different options (either MAP or TPS or mixed MAP or TPS) for the pressure control and gear tables, as you requested. This more complicated to do than I originally thought, and you will need to change some settings in TS (see the link for details). I have tested this on the bench, but it is certainly not exhaustively proven, so use it with great caution.
Re: 4r70w setup
