100% line pressure in reverse
Re: 100% line pressure in reverse
Those aren't errors as such. TS is just telling you that the MSQ's units and the current Project units aren't the same, and TS is not going to do anything about it. That is what you want it to do, so you can ignore the 'warnings', just make sure the units are set correctly under the 'Project Properties -> Settings -> CAN device' menu.
For more background, see this thread: viewtopic.php?f=12&t=503
Also, the 4.115 (and higher) code changed the name of the setting, from NOT_METRIC to IMPERIAL (see: viewtopic.php?f=4&t=240&p=3304#p3266). TunerStudio won't automatically understand the change, so you have to be sure to go in a change this setting (doing it as described in the previous paragraph). You may have to do this every time you switch between 4.114 and earlier code and later code (I would just create two different projects myself, one for 2.204 and one for the latest code).
