The MegaSquirt Project has experienced explosive growth other the years, with hundreds of new MS installations occurring every week - a phenomenal success! MegaSquirt has been successfully used in all aspects of Internal Combustion engine applications including R&D, Industry, Race, and Research. The MS project has transformed itself from a simple R&D project into a full-featured mature engine control system. To reflect this the support structure has also changed to meet the needs of MegaSquirt Users.
Moving forward, the R&D forums for MegaSquirt project are in a read-only mode - no new forum posts are accepted.
However the forums will remain available for view, they still contain a wealth of information on how MegaSquirt works, how it is installed and used. Feel free to search the forums for information, facts, and overview.While the R&D forum traffic has slowed in recent years, this is not at all a reflection of Megasquirt users, which continue to grow year after year. What has changed is that the method of MegaSquirt support today has rapidly moved to Facebook, this is where the vast majority of interaction is happening now. For those not on Facebook the msextra forums is another place for product support. Finally, for product selection assistance, all of the MegaSquirt vendors are there to help you select a system, along with all of the required pieces to make it complete.
Ok I have the 4l80 with a manual valve body and a trans brake. I have an air shifter on it which will shift up or down with steering wheel mounted buttons. Any possibility the megashift could be set up to up shift all gears with a single solenoid and then down shift all gears with another single solonoid. I know it's a strange application and I could go to an auto valvebody but I already have this set up working good. Any ideas.
It is not impossible that this could be controlled using the 'NAG mode' that is under development. NAG mode switches solenoids on to shift, otherwise they are off while in a gear.
I don't know enough of the details of your setup to say if this will work for you for sure though.
While several NAG functions are already in the code, there is currently no timeline for the NAG mode to be fully implemented, and it will probably be a while.
