Alternate input type for vss.
Tornadotech
Or can I just map one of the other inputs that accept that signal and then use it for the vss ?
I just built the mshift and am actually using it in my 4wd suburban with a 4l60e. The current vss has been difficult to get stable and then I still need to work on the output so my speedo and ABS will work.
Re: Alternate input type for vss.
Tornadotech,But, how do I modify the current vr input to accept that type?
It should work 'as is'. In fact, the circuit will be better than with a VR, if only because the zero-crossings are steeper and don't vary with RPM on either edge. The signal will still need to be clean, of course, just like with a VR.
4 pulses per revolution will work.
Tornadotech
I then realized that I was already using the vr3 for my up shift button. So I was wondering if that circuit and my sinking prox wouldn't be a better choice for my vr1 vss. I am running v4.125 .
One side question too, I was going to wire in my tach signal from the engine, but how is the tach signal used in the software ? Is it only used in rpm limits and slip calculations ? Or is there some other benefit ?
