Ford E4OD support
Ford E4OD support
Other that knowing that there is work on a MS based trans controller I know very little about the GPIO/MegaShift project.
I know the trans I have is the earlier one with the analog range selector.
There is the following:
Coast Clutch Solenoid
Shift Solenoid 1
Shift Solenoid 2
Converter Clutch Solenoid
Electronic Pressure Control Solenoid
Trans Fluid Temp Sensor
In addition there's also the VSS/TSS and the already mentioned analog range sensor that takes 2 wires, the neutral safety switch and backup lamp switch.
The VSS delivers 8 pulses per speedometer rotation. It piggybacks with the standard cable speedometer cable so it's speed can be changed by the drive and driven gear located inside the trans.
Will it work? Any tips? Ideas?
I'm thinking of getting the GPIO board and the Trans 'kit' from DIYAutoTune for it but should I look at something else?
David
Re: Ford E4OD support
The Coast Control Solenoid is used to provide engine braking while in gears 1-3. It should never be used in 4th as it will cause a tie-up condition where rotating parts inside the transmission stop rotating... It can be left off as the function is provided hydraulically in 1 and 2 if manually selected. Ford engages the CCS when the OD button is switched off.
Shift solenoids are as follows.
Gear | Sol 1 | Sol 2
P | On | Off
N | On | Off
R | On | Off
1 | On | Off
2 | On | On
3 | Off | On
4 | Off | Off
The EPS curve, based on a current aftermarket controller is 110ma at TPS 0 down to 0ma at TPS 100%. Production software is based off engine torque as a base pressure and TPS adds pressure as needed at the time of a shift. The aftermarket controller uses Alpha-N control to control the path to ground.
The temperature sensor is mainly to adjust line pressure for fluid below 0°F and above 220°F. It's not a linear scale though. Pressures rise when cold to account for the thicker fluid and rise when hot to account for expansion and extra internal fluid leakage. The adjustments are not huge I was told.
The Torque Converter Control is simply on/off. Later 4R100's are PWM. The E4OD can not do PWM without internal changes due to orifice restrictions. The restriction slows the TC lockup. Later 4R100's are 'wide open' so to speak and use PWM to control the speed of lockup.
The CCS in an interesting bag. It should only be on during coast and again, never in 4th. If it's left on in 1-3 it changes the trans from a non-synchronous shift to a synchronous shift. Timing is all electronic via the solenoids and Ford did make some synchronous shift transmissions for a desert race team and did very well with them. Timing is critical though as one clutch is added another must be released. If they overlap you have a tie-up and rotating parts stop rotating. If they're too far apart you have a slip and you have an RPM flair. This looks good for someone else to develop for a race effort. They won many race championships including the Baja 1000 several times. For me it's not worth it.
However, I will try and engage the CCS while in coast in 1-3 for engine braking. Since I don't like to go into OD till about 45-50mph that would allow me to drive around town with the trans in 3rd and engine braking available.
The shift solenoids are simple on/off - no PWM needed or even desired.
So it all boils down to whether or not the EPC can be controlled via PWM. I don't see why not. It won't be as efficient as current control but that little difference shouldn't matter. I plan on running a line pressure sensor so I should be able to tune with that.
Lastly, an FYI, there are two range selectors. The early one, 89-95 or so is analog. The later one is digital.
Here are the resistance values. On Fords they never added an extra detent for the extra gear. On the mechanical AOD there is no provision for 2nd gear - (D) D 1 is how the shifter is labeled. E4OD's use an O/D cancel button to manually limit it to drive only for towing/heavy load applications.
P = 3770-4607 Ohms (midpoint voltage - 4.41v)
R = 1304-1593 Ohms (midpoint voltage - 3.60v)
N = 660-807 Ohms (midpoint voltage - 2.83v)
(D) = 361-442 Ohms (midpoint voltage - 2.09v)
2 = 190-232 Ohms (midpoint voltage - 1.37v)
1 = 78-95 Ohms (midpoint voltage - 0.68v)
Gear ratios
1st = 2.71
2nd = 1.538
3rd = 1
4th = .712
Rev = 2.18
Solenoid Resistances
Shift Sol 1 20-30 Ohms
Shift Sol 2 20-30 Ohms
TCC Sol 20-30 Ohms
Coast Clutch Sol 20-30 Ohms
EPC Sol 4.25-6.50 Ohms
Temp Sensor:
32-58 Deg F 100k - 37k
59-104 Deg F 37k - 16k
105-158 Deg F 16k - 5k
159-194 Deg F 5k - 2.7k
195-230 Deg F 2.7k - 1.5k
231-266 Deg F 1.5k - 0.8k
EPC controls main line pressure, pulsed at appropriate duty cycles at 585Hz. Looks like normal voltages are between 7.5 and 12v.
Pressure in drive at idle should be about 75psi. Loaded (stalled) at about half throttle with your foot on the brake should be 145psi. With power disconnected it should be around 190-195psi.
I already listed the ohms/voltages for the analog range sensor used from 89 to 97. Some 97 E4OD models and all 4R100 models used a digital range sensor or Digital Transmission Range sensor (DTR). Here's the pinout information. The sensors physically interchange but the connectors are different and the factory analog PCM will not read the DTR. The early analog sensors suffered from water intrusion problems and a replacement/upgrade was issued in 1995. Given that MegaShift can do either I plan on upgrading to the later digital range sensor.
Terminals | Park | Rev | Neutral | Drive | 2nd | 1st
2 & 3 | Closed | 270Ω | 270Ω | 270Ω | Closed | Closed
2 & 4 | Closed | Closed | Closed | Open | Open | Open
2 & 5 | Closed | Closed | Open | Open | Closed | Open
2 & 6 | Closed | Open | Closed | Open | Open | Closed
9 & 11 | Open | Closed | Open | Open | Open | Open // Reverse switch
10 & 12 | Closed | Open | Closed | Open | Open | Open // Neutral safety switch
I think I have enough info to feel safe ordering a GPIO board and taking the next step... Unless I find something useful to post updates are likely going to be a while down the road... Hopefully not more than a few months though.
1 / 585 x 1000 = 1.709. Is that the correct formula for figuring that out?
Thanks, Chris
GPIO pin
1 12V power
2 VSS input
3 Brake sensor
4
5 2WD / 4WD switch
6 Overdrive switch
7
8
9
10
11
12
13 CANH to ECU
14
15
16 CANL to ECU
17 Sensor Ground
18 Ground
19 Ground
20 Ground / serial ground
21 Serial
22 Serial
23 #1 shift solenoid
24 Shifter analog input
25
26
27
28 VREF
29
30 Temperature sensor
31
32 Clutch control solenoid
33 Pressure control solenoid
34 Clutch coast solenoid
35 #2 shift solenoid
Do you need any additional information that I can try and dig up for you?
Lightning PCM Pin # Description
1 (Y) Keep Alive Power Input
2 (LG) Brake ON/OFF Switch Input
3 (GY/BK) VSS Input
4 (T/Y) Ignition Diag Monitor
5 NOT USED
6 (PK/O) VSS Ground
7 (LG/R) ECT
8 (DG/Y) Fuel Pump Monitor
9 (PK/LB) VIP Data Link Connector
10 (PK/LB) AC Cycle Pressure Switch Input
11 (BR) AIRD Solenoid Control
12 (LB/BK) Indicator Lamp to Low Range SW 4x4
13 NOT USED
14 NOT USED
15 NOT USED
16 (O/R) Ignition Ground
17 (PK/LG) Malfunction Indicator Lamp Feed
18 NOT USED
19 (P/O) Trans Shift Sol #2
20 (BK) PCM Case Ground
21 (W/LB)Idle Air Control Output
22 (LB/O) Fuel Pump Enable Output
23 (Y/R) Knock Sensor Input
24 (Y/LG) Power Steering Pressure Switch Input
25 (GY) IAT Input
26 (BR/W) Reference Voltage Output
27 (BR/LG) EGR Valve Position Feed
28 (T/O) VIP DLC
29 (GY/LB) HEGO
30 (LB/Y) Manual Lever Position Sensor (w E4OD)
31 (GY/Y) Canistor Purge Solenoid Output
32 (W/LG) Trans Control Indicator Lamp
33 (BR/PK) EGR Control Solenoid Input
34 NOT USED
35 NOT USED
36 (PK) SPOUT
37 ( R ) Power Input
38 (W/Y) Trans Electric Pressure Control
39 NOT USED
40 (BK/W) Ground
41 (T/W) Trans Control Switch
42 (O/BK) Transmission Oil Temp Input
43 (P) AC Panel Input
44 NOT USED
45 (LG/BK) MAP Input
46 (GY/R) Sensor Signal Return
47 (GY/W) TPS Input
48 (W/P) VIP Data Link Input
49 (O) HEGO Ground
50 NOT USED
51 (W/O) AIRB Solenoid Outlet
52 (O/Y) Trans Shift Solenoid #1
53 (P/Y) Trans Converter Clutch Solenoid
54 NOT USED
55 (BR/O) Coast Clutch Solenoid
56 (GY/O) Crankshaft Position Sensor Pickup
57 ( R )Power Input
58 (T) Injector (1,4,5,8)
59 (W) Injector (2,3,6,7)
60 (BK/W) Ground
Thank you guys in advance!
Raymond
