LED issue - flashing in reverse
The prn is working fine now, but i have found another bug in the ledpattern for reverse if i set led 4 on and in alternating pattern led 4 off, led 4 stays on so if i want a flashing 1 blank i get a alternating 1- 7.
If i set the basic pattern blank and alternating 1 it works perfect. All other outputs N 1-4 are oke.
And maybe would a separate output for Park be nice. Alternating like reverse if possible.
Jacco
Re: Latest Code Updates
Okay, thanks for spotting this, I will have a look shortly.
Re: LED issue - flashing in reverse
I have found and fixed a problem (a copy 'n paste error) with the LEDs in reverse that is very likely causing the problem you are seeing. I have attached fixed 2.201a code for you to try (uses the 2.201 INI here: http://www.msgpio.com/manuals/mshift/fi ... t_2201.ini).
If it works for you, this will become the 2.202 release code.
I will add this fix plus optional flashing for P and N to the 4.102 code (to become 4.103) in the next day or so.
