Target gear miss
Target gear miss
Long time no seen :mrgreen:
Just loaded the 4.145 code and had a run (first in a long time) I can see some strange behaviour in revese according to the log.
The car it self is behaving as it should though.
While in reverse cgear shows -1 but tgear shows 1 and just "blipping" down to -1.
There are some spikes in the vss but that is coming from my eletrical cooling fan (controlled by the MSIII) that by some strange reason is going on and off depending of gear lever position.....I'm tying to sort that out as well.....
(45.85 KiB) Downloaded 962 times
2014-08-09_15.02.56.msl
(613.1 KiB) Downloaded 1004 times
Re: Target gear miss
This is screen dump from MSIII under CAN-bus / Test modes.
Anyone any idea what VSS1 offset, Data Size and Gear# offset should be?
//Tobmag
VSS set-up.jpg (39.68 KiB) Viewed 20214 times
Yes, the target gear is still a positive number. It represents the gear the trans will shift to once MShift has control in the forward gears. In P, N, and R MShift is not controlling the target gear, it is just mirroring the gear lever position. So the target gear should be 1 under these conditions, because that is likely the gear you want once you shift to a controlled (i.e. forward) gear. It shouldn't really jump to -1, but it will do that if there are any gear lever errors such as the fan issue you mention (or remaining bugs in the code).
There offsets are in fourth column of the OutputChannels section of the INI:
[OutputChannels]
; These are from the outpc. structure in the main.c file of the source code
; the size and format are the same as above
   deadValue        = { 0 } ; Convenient unchanging value.
   ochBlockSize     = 72
 #if CAN_COMMANDS
;full version that works anywhere
   ochGetCommand    = "r\x01\x07%2o%2c"
#else
   ochGetCommand    = "a\x00\x06"
#endif
  seconds           = scalar, U16,    0,     "sec",      1.000, 0.0
#if SI_LENGTHS
  speedo            = scalar, U16,    2,     "kph",      0.16093, 0.0
  odometer          = scalar, U32,    4,      "km",      0.00161, 0.0
#else
  speedo            = scalar, U16,    2,     "mph",      0.100, 0.0
  odometer          = scalar, U32,    4,   "miles",      0.001, 0.0
#endif
  auto_mode         = scalar, U08,    8,       " ",      1.000, 0.0
  downbutton        = bits,   U08,    9,   [0:0]
  upbutton          = bits,   U08,    9,   [1:1]
  downshift_request = bits,   U08,    9,   [2:2]
  upshift_request   = bits,   U08,    9,   [3:3]
  error             = scalar, U08,   10,       " ",      1.000, 0.0
  serialComm        = bits,   U08,   10,   [0:0]
  CAN error         = bits,   U08,   10,   [1:1]
  revshiftblock     = bits,   U08,   10,   [2:2]
  VSSreset          = bits,   U08,   10,   [3:3]
  VSSerr            = bits,   U08,   10,   [4:4]
  gearRangeErr      = bits,   U08,   10,   [5:5]
  lowVolts          = bits,   U08,   10,   [6:6]
  noBrake           = bits,   U08,   10,   [7:7]
  manual_gear       = scalar, S08,   11,       " ",      1.000, 0.0
  current_gear      = scalar, S08,   12,       " ",      1.000, 0.0
  target_gear       = scalar, S08,   13,       " ",      1.000, 0.0
  engine_rpm        = scalar, U16,   14,     "rpm",      1.000, 0.0
#if LOAD_KPA
  LOAD              = scalar, S16,   16,     "kpa",      0.100, 0.0
#else
  LOAD              = scalar, S16,   16,       "%",      0.100, 0.0
#endif
#if CELSIUS
  clt               = scalar, S16,   18,    "ºC",        0.055556, -320.0
#else
  clt               = scalar, S16,   18,    "ºF",        0.100, 0.0
#endif
#if SI_LENGTHS
  linepressure      = scalar, S16,   20,     "bar",      0.00689, 0.0
#else
  linepressure      = scalar, S16,   20,     "psi",      0.10, 0.0
#endif
  lock_TCC          = scalar, U08,   22,       " ",      1.000, 0.0
  brake             = bits,   U08,   23,   [0:0]
  burnstatus        = bits,   U08,   23,   [1:1]
  FWD               = bits,   U08,   23,   [2:2]
  forceUP			= bits,   U08,   23,   [3:3]
  forceDWN			= bits,   U08,   23,   [4:4]
  JakeBrake         = bits,   U08,   23,   [5:5]
#if LOAD_KPA
  LOAD_short        = scalar, U16,   24,     "kpa",      0.100, 0.0
#else
  LOAD_short        = scalar, U16,   24,       "%",      0.100, 0.0
#endif
  aux_volts         = scalar, U16,   26,       "V",      0.001, 0.0
  PC_duty           = scalar, U08,   28,     "pct",      1.000, 0.0
  slip              = scalar, U08,   29,     "pct",      1.000, 0.0
  dbug              = scalar, U16,   30,       " ",      1.000, 0.0
  In1adc            = scalar, U16,   32,   "volts",      0.00488, 0.0
  In2adc            = scalar, U16,   34,   "volts",      0.00488, 0.0
  In3adc            = scalar, U16,   36,   "volts",      0.00488, 0.0
  solst             = scalar, U08,   38,       " ",      1.000, 0.0
  Output1           = bits,   U08,   38,   [0:0]
  Output2           = bits,   U08,   38,   [1:1]
  Output3           = bits,   U08,   38,   [2:2]
  Output4           = bits,   U08,   38,   [3:3]
  Output5           = bits,   U08,   38,   [4:4]
  Output6           = bits,   U08,   38,   [5:5]
  Output7           = bits,   U08,   38,   [6:6]
  Output8           = bits,   U08,   38,   [7:7]
  chcksum           = scalar, U08,   39,       " ",      1.000, 0.0
  mileage           = scalar, U16,   40,     "mpg",      0.010, 0.0
  FuelAdj           = scalar, S16,   42,       "%",      0.100, 0.0
  SpkAdj            = scalar, S16,   44,       "°",      0.100, 0.0
  IdleAdj           = scalar, S16,   46,       " ",      1.000, 0.0
  SprAdj            = scalar, S16,   48,       " ",      1.000, 0.0
  In1               = bits,   U08,   50,   [0:0]
  In2               = bits,   U08,   50,   [1:1]
  In3               = bits,   U08,   50,   [2:2]
  In4               = bits,   U08,   50,   [3:3]
  sp1PWM            = scalar, U08,   51,      "%",       1.000, 0.0
  is_rpm            = scalar, U16,   52,    "rpm",       1.000, 0.0
  butADC            = scalar, U16,   54,  "volts",     0.00488, 0.0
  sp2PWM            = scalar, U08,   56,      "%",       1.000, 0.0
  TCC_count         = scalar, U08,   57,    "sec",       0.100, 0.0
  sp0PWM   			= scalar, U08,   58,      "%",       1.000, 0.0
  sp09inx           = scalar, U16,   59,       ""'       0.100, 0.0
  sp016inx          = scalar, U16,   61,       ""'       0.100, 0.0
  ms2tps            = scalar, U08,   63,       "",       1.000, 0.0
  LED1              = bits,   U08,   64,   [0:0]
  LED2              = bits,   U08,   64,   [1:1]
  LED3              = bits,   U08,   64,   [2:2]
  LED4              = bits,   U08,   64,   [3:3]
  dbugout7          = scalar, U08,   65,       "",       1.000, 0.0
  dbugout6          = scalar, U08,   66,       "",       1.000, 0.0
  dbugout5          = scalar, U08,   67,       "",       1.000, 0.0
  dbugout4          = scalar, U08,   68,       "",       1.000, 0.0
  dbugout3          = scalar, U08,   69,       "",       1.000, 0.0
  dbugout2          = scalar, U08,   70,       "",       1.000, 0.0
  dbugout1          = scalar, U08,   71,       "",       1.000, 0.0
  ;     pageSize =  71 + U08 = 72
So VSS (= speedo) is 2, the gear is in 11, 12, or 13 depending on whether you want the lever position, the current gear, or the target gear (so probably 12).
If I understand this correctly, the data size you are looking for is in the Uxx or Sxx term in the third column. S08 is 8 bits (1 byte), U16 is 16 bits (2 bytes). Uxx means an unsigned value (no negative numbers), and Sxx means signed (plus and minus numbers, but the maximum is only 1/2 as much). The speedo value is U16, so 16 bits. The gear value is S08 so 8 bits (the current gear value needs to allow negative numbers to have a reverse gear, and we certainly don't need a gear range over 127 in any case!).
The table should be 7 (but 6 might work too)
Thanks for promt reply, well with data size I can only choose 8bit or 16bit from the dropdown table, Explanations says "How the data is stored on the expansion board. See documentation"
12 is probably correct for Gear# since the fan by some reason is going on/off depending of where I put the lever, not correct so will adress that at MSIII forum.
gui67
Post by gui67 »
Hello,
Here is how my MS3 is set.
It works right for speed and gear
Thanks gui67, Ill give it a try next weekend.
Do you use MSIII to control any electrical cooling fan? I have my wired up that way using NOS1 output, it behaves very strange when I use 16bit.
If fan is running and I put it in anything but P or N it will cut the fan.......
Very soon I'll have the car in the new house I'm moving in to, 75m3 garage/workshop in the basement :D (instead of driving 45km to the garage....)
//Tobmag
gui67
Post by gui67 »
Yes, I use MS3 to control a fan, but it nearly never goes on. I never noticed such a behaviour, but I will check next time.
Guillaume
