manual shift options?
Posted: Tue May 27, 2014 8:41 am
After getting this Ford 4R75W trans working pretty well, I have started to lean on it a little harder to see how it performs. On my truck I currently have a Lokar shifter setup and no electric shift buttons yet. I do plan on creating some sort of shift paddles/buttons down the road, but I would like the shifter to function more like a manual shift would also. Is that possible? does it already do this? I read through a bunch of docs but didn't see anything specifically. I saw the burnout mode you recently added and it looks to be closer to what I would like.
My thought is that when O/D is disabled (I am using ground button input) the manual lever position should function the same as shift buttons would. I want it to be a true manual mode and downshift when I pull the lever into 2nd or 1st and not shift until I shift (unless above X rpm or whatever.) It kind of acts like a true manual input when I manually shift at times, and other times it doesn't seem to function like one. I haven't spent enough time on it to see if I have an issue somewhere if it really isn't set up to function like I was wanting/expecting.
Also....mostly unrelated. I got the TCC operating correctly now. I put a new range sensor in and that has cleaned up most of my random weird intermittent issues, which I suspected was a crappy input on the manual gear input.
I plan to update to 5.0x this week and play with some of the extra features.
Andrew
Andrew
