Delay to shift gears
Posted: Wed Oct 16, 2013 4:53 am
by shaodome
I'll post my MSQ in a few hours but for some reason I am expereiencing a weird extended delay before the ECU will shift to 4th. Looking at the gear shift table it is well within the bins that are 4th gear and the Hysteris clear is green in tuner studio (I'm assuming that means the engine is outside the limits of the shift factors set, thus allowing the shift) and it will just hang there taking a long time regardless of RPM. There is something else causing the delay I just don't know what it is.
I have the load smoothing factor set to 1000. Think that is the cause or other things to look at?
Re: Delay to shift gears
Posted: Wed Oct 16, 2013 8:35 am
shaodome,
There are all sorts of things that can block a shift, from hysteresis to rpm protection. It hard to say what's going on in your case without an MSQ and datalog.
