Base GPIO code to work from?
Thanks Ryan
Re: Base GPIO code to work from?
You might grab the early trans code project here: http://www.msgpio.com/manuals/mshift/GP ... E_Proj.zip The main source code with the hints is here: http://www.msgpio.com/manuals/mshift/4L60E_main.c It is for CW 4.6 (but will likely work for other versions).
There is an outline of the code flow and functions here: http://www.msgpio.com/manuals/mshift/4L60Ecode.html
It contains a ton of hints (and working examples) of how to write code for the HCS12 processor.
http://www.msgpio.com/manuals/iocode/code.htm
This project has:
- serial and CAN comms infrastructure already in place,
- ALL the MS-II output variables are read into the GPIO and are available for use in conditions, etc. (some are not yet assigned to variables, the code shows how to do this),
- the ADC, PWM, and digital I/O all set up for a number of ports (24 of them),
- a number of 'pre-defined' user input parameters (of the form typevariableXXX, ex. charvariable007) ready to use in the program via tuning software (MT or TS),
- all the inputs are read and assigned to variables (and reported/logged in the tuning software),
- samples of how to control 12 of the outputs using various settings.
The code compiles fine with the free 'special edition' on Codewarrior (see the link for how to get this).
This should make it much easier for new programmers to get started writing their own code for the GPIO.
I haven't tested the project at all on the actual hardware (since it doesn't really do much!), but will do that soon. It's not impossible that I have some of the ports/circuits wrong (since the MegaShift code this is based on swapping a few circuits). I will check this when I get a chance. If anyone sees anything that doesn't look right, please let me know.
I want to create an airride controller using data from my MS2 and inputs into the GPIO to change ride height based on vehicle speed and other variables.
Thanks Ryan
Found out code warrior does not work with Vista X64, so now I'm on the hunt for code program for the HCS12 which will work with vistax64.
I will update the project shortly (http://www.msgpio.com/manuals/iocode/code.htm).
These comments apply especially to new programmers.
Firstly I think the code looks solid, I have no issues there.
There is one error though
When describing how #include files work. It's not really like that.
The Code warrior help says this;
*Note that both styles cause the directive (#include) to be replaced by the entire contents of the file, not just the quoted version..
The search for include files is governed by two environment variables: GENPATH: #include "File" Path and LIBRARYPATH: 'include <File>' Path.
Include files that are included using double quotes as in:
#include "test.h"
are searched first in the current directory, then in the directory specified by the -I: Include File Path option,
then in the directories given in the GENPATH: #include "File" Path environment variable, and finally in those listed in the LIBPATH or
LIBRARYPATH: 'include <File>' Path environment variable. The current directory is set using the IDE, the Program Manager, or
the DEFAULTDIR: Default Current Directory environment variable.
Include files that are included using angular brackets as in
#include <stdio.h>
are searched for first in the current directory, then in the directory specified by the -I option, and then
in the directories given in LIBPATH or LIBRARYPATH. The current directory is set using the IDE, the Program Manager, or
the DEFAULTDIR environment variable.
My main issue is mostly style, or lack of it.
Or is it that every possible style seems to be used?
I'm not objecting to the bracket placement as that is a personal preference issue
ie.
if(...) {
vs
if(...)
When you modify code that someone else has written, suck it up and use their style.
Put a blank line before and after logical blocks of code, like an if, while or just a group of variables that are related.
Crunching everything together does not make you code smaller, the compiler doesn't care
indent!
reverse or random indenting makes reading the code hard. Clean consistent indenting makes life SO much easier esp when reviewing new code or code you haven't seen in a year.
Which is easier to read;
This
switch(txmode){
case 0:
switch(SCI0DRL){
case 'a': // send back all real time ram output variables
next_txmode = 1;
txmode = getCANid;
cksum = 0;
break;
case 'w': // receive new ram input data and write into offset location;
// also used for forwarding CAN msgs bet. MT & auxilliary boards.
// In this CAN mode, no_bytes must be >0 and <=8.
next_txmode = 5;
txmode = getCANid;
rd_wr = 1;
break;
case 'e': // same as 'w', but verify by echoing back values. Don't use with CAN
next_txmode = 5;
txmode = getCANid;
rd_wr = 2;
break;
switch(txmode)
case 0:
switch(SCI0DRL)
next_txmode = 1;
txmode = getCANid;
cksum = 0;
break;
next_txmode = 5;
txmode = getCANid;
rd_wr = 1;
break;
next_txmode = 5;
txmode = getCANid;
rd_wr = 2;
break;
Hope this isn't too much of a rant!
Keith
The function get_adc()
It returns an int.
The problem is the variable it returns (adcval) is a global, meaning it is defined outside the function.
The variable is not used anywhere but inside get_adc()
There are 2 better solution to this.
1. move the variable declaration inside the function
2. use the global variable and don't return anything.
For those interested the reason returning a global variable is not desireable is that it's the worst of both worlds problem.
Since it is declared global, it always exists taking up memory.
When you return it, unless the compiler is really smart, you have 2 copies of the variable, 2x the memory.
lastly, leaving the global around polutes the general codespace, making it unecessarily cluttered.
If you declare the variable inside the function and return it. It only uses memory while that function is running.
Much better
like this;
int get_adc(char chan1)
signed int adcval; // signed for possible negative temperatures
Why is this done'
#define pPTM ((volatile unsigned char*)(0x0250))
volatile unsigned char *pPTMpin[8];
// Set pointers to real port addresses
for(ix = 0; ix < 8; ix++)
pPTMpin[ix] = pPTM; // port M
pPTTpin[ix] = pPTT; // port T
} // end for (ix = 0...
Then they are used like this;
// turn off output pins
*pPTMpin[2] &= ~0x04; // 0x04 = 00000100, ~0x04 = 11111011, turn off Sol B @ PM2
*pPTMpin[3] &= ~0x08; // 0x08 = 00001000, ~0x08 = 11110111, turn off LED2 @ PM3
*pPTMpin[4] &= ~0x10; // 0x10 = 00010000, ~0x10 = 11101111, turn off LED1 @ PM4
*pPTMpin[5] &= ~0x20; // 0x20 = 00100000, ~0x20 = 11011111, turn off LED3 @ PM5
(why make an array of pointers to the same address?)
#define PTM (*(volatile unsigned char*)(0x0250))
PTM &= ~0x04;
PTM &= ~0x08;
PTM &= ~0x10;
PTM &= ~0x20;
