Running a 4L60E with default settings.
Posted: Fri Nov 11, 2011 6:01 am
by ka24deroadster
I am hooking up a MSII and a GPIO to my 1996 LT1 with a 4L60E tranny. Everything I have read says that the default settings for the GPIO is for the 4L60E. Can I just run the default settings and not have to worry about them?
Re: Running a 4L60E with default settings.
Posted: Fri Nov 11, 2011 6:28 am
ka24,
I would review them against the manual:
http://www.msgpio.com/manuals/mshift/V2tune.html, if this was mine. You will learn about how the system as a whole works, what options you have to adjust things, and how it should all be wired. There are also some optional setting for spare outputs, etc. that you may have to adjust (since they aren't necessarily targeted at any one trans), depending on what you hope to use them for.
