Temperature vs. Line Pressure Adjustments
Posted: Tue Aug 09, 2016 5:14 pm
Has anyone successfully used this feature? I want to command higher line pressure when the transmission is cold and have it ramp down once at operating temp. I tried changing the values from zero to either a positive or negative interger. After making changes I see some really strange PC PWM% values and the actual pressure(displayed on external gage) drops dramatically and the trans slips.
Thanks for the help and suggestions. Rob
