Page 6 of 6
Posted: Sun Sep 29, 2013 10:09 am
Tobmag, ashford;
I'll pick some of these up in the next week or so, and post here when I have some ready to send out.
Posted: Wed Oct 16, 2013 10:21 am
by tobmag
well attached a log of the LM2907 circuit on both ISS and VSS, both inputs gets the same signal here on the bench since my function generator only has 1 output.
This is a sweep from 1hz to 2000hz over 50sec. signal is rock steady, input masking is set to 0 !!
Next up will be the max9926 circuit
//Tobmag
Posted: Wed Oct 16, 2013 3:02 pm
I have ordered the parts mentioned above (2907 and 1124). If you want either or both of them, PM me with a shipping address and I will get them in the mail.
Others who would like to test should do the same (you must have a GPIO installed with MShift controlling the transmission in a functioning vehicle, otherwise please don't ask for these samples).
Posted: Sat Nov 09, 2013 12:49 pm
by tobmag
I have done some test with the max9926 circuit and its working as a dream here on my bench.
Probably the smothest signal I seen so far.
Stacked everything up and did some test in the car.
Here the fun stopped, probably the most sensitive circuit on the market it manage to pick every sort of noice making the the output signal useless.
Now this is my install might be that it will work fine for others.
I can post some logs from the bench test if enyone is interested, didnt bother to make any log in the car.
//Tobmag
Posted: Sat Nov 09, 2013 2:13 pm
Yeah, that's always the trouble: finding the 'sweet spot' between getting the full signal from the sensor but rejecting all of the noise. Did you experiment with any of the masking in the code on the car?
Posted: Mon Nov 11, 2013 9:35 am
by tobmag
No I didnt bother about that, I spent so much time with the MicroTCU that uses the same circuit and same problem....
Posted: Wed Nov 13, 2013 11:59 am
by pigga
tobmag wrote:I have done some test with the max9926 circuit and its working as a dream here on my bench.
Hi Tobmag.
As I am willing to "megashift" a gearbox, I am a bit afraid of facing the same problems.
However: I had some issues with the VR input on the V3 board as well (above all at cold starts in winter when the starter acts a bit clumsy).
Since I converted to some of the "Dual VR boards" (AFAIK there are at least two dealers that offer that) based on the MAX9926, it works like a charm. Maybe this is of any help for you?
Posted: Thu Nov 14, 2013 4:43 am
by tobmag
Pigga.
I assume you use them for engine speed? That will be a completly different story since it will never see any "low" frequenses.
I have the dual bord from the Canadian guy, this one is not in any way working in my car....on the bench perfectly.
Gui76 here at the forum has the same board and have issues as well.
I just recieved the NCV1124 circuit from Lance so will have that testsed in a week or so.
Thanks for the heads up anyway.
