Adding current load to PWM output circuit?
Also, I've never written any code besides intro to VB in college. Could I (or some nice people) write a code to turn the pump on at a certain coolant temp and relay the pump straight to battery at full throttle? I could accomplish this with a temp sensor and a throttle switch but I'd again, rather keep it simple.
antony
1990 VW G60, MS2 V3.0
Re: Adding current load to PWM output circuit?
I am not sure if the traces on the production board are capable of carrying a sustained 8 Amps. On the beta units, the VBx circuits can carry more current than the PWM circuits - they have thicker traces (and they can still do PWM). VB1 had extra heavy traces for the highest current rating. I'll have to ask Bill about the trace limits on the production boards.
Al has written general purpose code that does switching based on a number of inputs (including those measured in the GPIO itself and those sent from MS-II via CAN). I am documenting this code and need to write an INI for it yet, and I am doing this now. The draft code is here: http://www.megamanual.com/gpio/code.htm, new code will be uploaded shortly (the location will change, and will be linked from http://www.msgpio.com/manuals/)
