CodeWarrior Help
A forum for discussing the applications and implementations of the DIY general code template for the GPIO and its 25 user inputs and outputs (+ serial & CAN). The code is 99% complete, the user just has to add their own conditional I/O logic and compile (with a free special Edition of CodeWarrior).
ngcontrol
CodeWarrior Help
Post by ngcontrol » Fri Mar 05, 2010 10:46 am
I have CodeWarrior IDE version 5.9.0 build 2836. I start Codewarrior and open the template.mcp, but then I do not understand how to make a new s19 file. Could someone help out, or point me to where I could find this info?
Re: CodeWarrior Help
Post by Bernard Fife » Fri Mar 05, 2010 12:37 pm
ngcontrol,
To compile (actually compile/link/locate) the code in Codewarrior, you use the 'Project/Make' menu item (or the F7 key for a shortcut). That will create a S19 file in the projects /BIN/ folder from the source code. It will also create a number of other files that detail how the compiling was done (where variables are located in memory, for example).
ngcontrol
Post by ngcontrol » Fri Mar 05, 2010 4:48 pm
Sure enough, there they are. I have much to learn. Thanks for the help.
