Question about TPS/load
For discussing Phil Tobin's TunerStudio MS is the MegaSquirt edition of TunerStudio, a next generation tuning application. It provides the ability to configure and tune all GPIO/MShift(tm) controllers and is 100% compatible with MegaTune ini files and msq's.
Brittain G
Post by Brittain G » Fri Sep 09, 2016 8:06 am
I was wondering, if you have set the parameters for TPS load table and have MAP versus TPS for LOAD: set to "0" so you are running only TPS. Do the load values in the shift table now represent the percentage of throttle open? (30kpa = 30% tps)
Thank you.
